2
Author Topic: PWM (PIC 16F 877A) for window climbing robot...???  (Read 4046 times)
Offline katherinaTopic starter
« on: September 30, 2007, 11:22:57 PM »
hi, me n my partner is trying to develop a window climbing robot using the PIC 16F877A to control its operation.
Im wondering, since the PIC 16F877A has only 2 pwm, n i dun intend to control the speed of the robot which in dat case, pwm have to be used.  here, i only need to control the angle of rotation  for 3 motors.
we wanted to develop something almost similar to below for our final project (we use this as our reference, and this is where we got the idea from):
http://www.mech.utah.edu/~minor/publications/IROS00-climber.pdf
if we need to use the pwm, we need 3 pwm. however, in PIC 16F877A they only have 2 pwm... does dat mean that i have to use 2 Chips of PIC116F877A???
tq....
Offline creedcradle
  • Physics Robotics
Re: PWM (PIC 16F 877A) for window climbing robot...???
« Reply #1 on: October 01, 2007, 02:13:33 AM »
tq....
a big NO.
i want to show you here the trick how to create a PWM with the  use of the ordinary PINs of any PIC MCU
here it goes
preconditions;
crystal is at 4 MHZ
 org 0x000
INITPORT
                   bsf     STATUS,RP0
         movlw   00h
         movwf   TRISB
         bcf     STATUS,RP0
         clrf    PORTB
SIMULA
             movlw   d'40'
             movwf   kaliwa_cntr
KALIWA
         bsf     PORTB, 0
         movlw   d'1'         ;decimal value for 1ms (para sa 4MHz oscillator)
             movwf   Delay_time
         call    BAGAL
         bcf     PORTB, 0
             movlw   d'20'
             movwf   Delay_time
             call    BAGAL
         decfsz  kaliwa_cntr
             goto    KALIWA
             movlw   d'40'
             movwf   kanan_cntr
KANAN
         bsf     PORTB, 0
         movlw   d'2'
             movwf   Delay_time
         call    BAGAL
         bcf     PORTB, 0
             movlw   d'20'
             movwf   Delay_time
             call    BAGAL
         decfsz  kanan_cntr
             goto    KANAN
             call    SIMULA
BAGAL
        movlw d'248'
           movwf Delay_Cntr
delay1ms
           nop
           decfsz Delay_Cntr
           goto delay1ms
           decfsz Delay_time   ; 1ms; 2m O 20 ms
           goto BAGAL
        return
            end
A little math makes a PWM works
« Last Edit: October 01, 2007, 02:16:19 AM by creedcradle »
LEARN TO SHARE and SHARE TO LEARN!
« Reply #2 on: October 01, 2007, 05:54:04 AM »
but, dats in 'assembly' language rite?
we have to do the program in c....
i dun have any idea ???
Offline annoyin_kid
« Reply #3 on: October 01, 2007, 12:36:04 PM »
y not get 3 servos and mod them just change the duration of the pulse and you get different speeds? im pretty sure that you can use them on any output pin i know that you can with picaxe but im not 100% with PIC 16F877A. only problem is that you will lose a lot of speed but you'll get much more torque.
can i just ask wot the window climbing thing is for? u planning to break into a house or something?
« Last Edit: October 01, 2007, 12:37:15 PM by annoyin_kid »
Offline creedcradle
  • Physics Robotics
« Reply #4 on: October 01, 2007, 03:59:50 PM »
if you do it in C it is much easier,
just remember any general I/O pin can be modulated with a simple use of a loop
say
while (1)
set an I/O pin to high
delay in microsec(1000)
set the I/O pin to low
delay in microsec (20000)
it makes the servo moves forward
