Author Topic: Can a servo controller control this motor controller?  (Read 2776 times)
Offline GertlexTopic starter
  • Helpful? 23
« on: October 14, 2007, 04:01:32 PM »
Hi guys,
My bluetooth R/C car, mentioned in the past, currently uses two servos as mechanical method of switching polarity and controlling speed on the car.  I use a servo controller rather than a microprocessor.  Obviously, my method isn't the ideal (though it works very well, except that I can easily burn out the rheostat that I'm using).
I've found this piece of hardware:
http://www.superdroidrobots.com/shop/item.asp?itemid=700&catid=5
It's got the standard 3wire servo connector on it.  Does this mean I can hook it up to my servo controller (Mini SSC II) and control it with byte values (0 - 255)?
I
Offline jsmoker
Re: Can a servo controller control this motor controller?
« Reply #1 on: October 15, 2007, 01:16:49 PM »
yes,  I've used a unidirectional ESC, but this should be the same thing.  It simply works on a servo signal and translates it into an output.  The said "pushbutton" seems like that's what centers it so if you have a 128 (from your 0-255 range) (aka, ~1.5ms pulse width) output and you push the button that'll designate that the center, or if you have 6 it'll do the same, though leaving very little room for one direction.  I would assume it saturates at the other end as well.  the one I have is already pre-configured to have stop at one end and ramps up from there.  Well, hope this helps.
-J
  • Helpful? 23
« Reply #2 on: October 15, 2007, 03:32:32 PM »
Thanks, that pretty much verifies what I thought.  Crazy though, that it costs more than the servo controller did.
I'd assume that it's plenty fast too *shrug*.
Not going to buy it yet, but it's good to keep such in my bookmarks.
I
« Reply #3 on: October 19, 2007, 08:17:21 PM »
just a note, http://www.servocity.com and http://www.dimensionengineering.com also have similar products (for controlling DC motors with servo signals)
Last post December 11, 2006, 12:06:41 PM
Last post May 24, 2008, 06:30:12 PM
by JesseWelling
Last post May 09, 2011, 06:50:02 PM
by Webbot
Last post August 22, 2012, 08:28:44 PM
by cgrenier
