Author Topic: micro-switch help  (Read 2621 times)
Offline ltmhallTopic starter
micro-switch help
« on: October 25, 2006, 04:52:13 AM »
Could some one explain how a microswitch works for a collision detection circuit, and where I can buy one? I don’t want to use whiskers, and I’m not sure if I need to design some kind of skirt.
Re: micro-switch help
« Reply #1 on: October 25, 2006, 06:49:18 AM »
Whiskers are required . . .
here is a quickie tutorial for microswitch tactile collision detection . . . its one of those tutorials i never really developed fully . . .
Offline JesseWelling
  • Only You Can Build A Robot!
« Reply #2 on: October 25, 2006, 02:52:27 PM »
also decent for the detection of being high centered (or better yet use two and detect if you *might* get highcentered)
« Reply #3 on: November 11, 2006, 07:58:20 AM »
I have three positions on my microswitch Common, Normally Open, and Normally Closed. How would I connect them to a microprocessor.
« Reply #4 on: November 11, 2006, 01:11:48 PM »
your microswitch only has two positions: open and closed.
however there would be three connections for wires: common (ground), normally open, and normally closed. you only need 2 of them.
connect common to ground, and connect either normally open OR normally closed to a digital output. all that means is one connection will give you a binary high (until switch is pushed), and the other will always give a binary low (until switch is pushed). for a microcontroller it doesnt matter which one you choose.
Last post March 10, 2008, 07:56:13 PM
by Trumpkin
Last post May 26, 2008, 04:27:32 AM
by Steel_monkey
Last post May 27, 2010, 04:22:54 AM
by amando96
Last post April 17, 2012, 11:11:12 PM
