Author Topic: Motor Control Using Back-EMF techniques  (Read 2219 times)
Offline Steve JoblinTopic starter
« on: October 19, 2007, 08:47:20 AM »
I understand that a good method of motor control is to use back-emf.  I can't seem to find much about it via posts on these forums and/or Google.  Can someone point a newbie like me to a good source that provides an "idiots guide" and some samples to get me started?  It seems like a great technique for motor control, but I know of only one company (Acroname) that is using it in a product (http://www.acroname.com/robotics/parts/S11-3A-EMF-HBRIDGE.html). Why don't more hobby motor controllers utilize this technique?
Offline hgordon
  • Helpful? 7
Re: Motor Control Using Back-EMF techniques
« Reply #1 on: October 19, 2007, 11:09:55 AM »
We're using it, though we are measuring pulse widths using a "zero crossing" technique rather than measuring voltage.  You'll find some information on our explorations here -
    http://www.surveyor.com/cgi-bin/robot_journal.cgi/2007/06/10#099
The motor control board for the new version of our robot has this circuit for 2 motors with only minor modification - you'll find the schematic in the middle of the page of
    http://www.surveyor.com/blackfin/
Surveyor Corporation
  www.surveyor.com
« Reply #2 on: October 19, 2007, 11:53:12 AM »
The back emf solution would only work for perfectly flat terrain . . . add slopes (or collisions, or change robot weight) and it breaks . . . note that back emf has error rates as well.
Ive seen it used in conjunction with encoders to detect slip (wheels spin, but no emf from torque).
Offline hgordon
  • Helpful? 7
« Reply #3 on: October 19, 2007, 12:10:55 PM »
It definitely requires some signal processing to get good data, but we only sample for a few milliseconds at a time, and this can be compensated for by slightly boosting power levels (PWM width).  There's no dead reckoning technique that will produce perfect results, but the benefit of back-emf is that it's REALLY cheap to implement - our parts cost for 2 channels is under $1.00.
  www.surveyor.com
Last post May 08, 2007, 02:58:53 PM
by JonHylands
Last post August 11, 2007, 11:20:51 AM
Last post March 27, 2008, 03:07:24 PM
Last post October 29, 2012, 03:23:54 PM
