Author Topic: Potentiometer  (Read 1390 times)
Offline YAN-1Topic starter
Potentiometer
« on: October 24, 2007, 01:17:03 AM »
Hello everyone. I am in a huge need of a sliding linear potentiometer that is 9-10 cm long (travels 10 cm from one end to the other to cover the whole range), and that has a total resistance of 1 kilo-ohms or 2 kilo-ohms. Can anyone direct me to where I can obtain/purchase such a sliding potentiometer? Thanks a lot.
Offline bulkhead
Re: Potentiometer
« Reply #1 on: October 24, 2007, 01:35:03 AM »
I'm not sure where such a large one can be found, but as for the total resistance, it can be compensated for by adding a resistor in series (if the desired resistance is higher) or in parallel (if the desired resistance is smaller).
Offline HDL_CinC_Dragon
Re: Potentiometer
« Reply #3 on: October 24, 2007, 08:50:51 PM »
dont suppose you could use a radial potentiometer and just put a pinion gear on it and have a rack be on this moving object of yours so that as the rack moves it turns the pinion gear thus turning the potentiometer?
just a suggestion...
United States Marine Corps
Infantry
Returns to society: 2014JAN11
Last post December 07, 2007, 09:00:44 PM
by paulstreats
Last post May 23, 2008, 07:03:10 PM
by Webbot
Last post February 25, 2011, 06:08:53 PM
by hopslink
Last post March 03, 2011, 10:27:40 PM
by Xyver
