Author Topic: Servo Motors at 180 Degrees  (Read 1934 times)
Offline stt585Topic starter
« on: October 29, 2007, 03:34:12 PM »
Hi, I am working on a robot that needs needs a sensor suite that looks directly right and left with all possible angles in between.
I am planning on mounting these sensors on a servo motor that can at least rotate 180 degrees.  Can anyone help me out?  Most servos don't list the operating range of movement at all, so if anyone knows of any servos that fit that description, that would be great.
Regards
-Steve
Offline frank26080115
Re: Servo Motors at 180 Degrees
« Reply #1 on: October 29, 2007, 03:53:32 PM »
standard servos can all rotate about 90 degrees to each side, so 180 degrees total
digital servos allows you to actually specify a range if you need that feature
Last post January 15, 2009, 04:33:28 PM
by jediryan123
Last post April 08, 2009, 08:07:49 PM
by Razor Concepts
Last post February 04, 2010, 10:43:36 PM
by Razor Concepts
Last post November 19, 2010, 09:21:33 AM
by electrafan
