Author Topic: Infrared Emitter Detector Amplified Signal Circuit($50 robot)  (Read 2508 times)
Offline mobzTopic starter
« on: November 04, 2007, 08:10:31 PM »
If someone could tell me
1) why we need to amplify the output of the detector circuit?
2)Why do we give the phototransistor Voltage?(Vcc)
3)how do i modulate the the signal to avoid interference from ambient light?
Any input will be highly appreciated..
Offline frank26080115
Re: Infrared Emitter Detector Amplified Signal Circuit($50 robot)
« Reply #1 on: November 04, 2007, 10:27:27 PM »
amplification is not really needed
also, to avoid the problem of ambient light, what i do is take a first reading, use a mosfet to turn on the emitter, take 2nd reading, turn off emitter, then compare the two readings for percentage difference
