Author Topic: PC TO AVR serially  (Read 3279 times)
Offline benjiTopic starter
PC TO AVR serially
« on: November 10, 2007, 04:34:55 PM »
I need to send data from my PC to the hooked avr through serial port,
how do i make a c or visual c++ program on a pc to send/recieve data to/from the avr?
(i totaly know how to program the avr USART, my problem is on the PC side )
thanks already for any help
good ol' BeNNy
Offline JesseWelling
  • Only You Can Build A Robot!
Re: PC TO AVR serially
« Reply #1 on: November 10, 2007, 06:51:37 PM »
I recently had a  c# data logging project...
http://msmvps.com/blogs/coad/archive/2005/03/23/SerialPort-_2800_RS_2D00_232-Serial-COM-Port_2900_-in-C_2300_-.NET.aspx
You can get free .Net Express stuff here:
http://msdn2.microsoft.com/en-us/express/default.aspx
I prefer Linux however and some other people might too. If some one is looking for a good example of that, here is a good example that I've used often for reference:
*   Copyright (c) 2006 Dave Hylands
*   This program is free software; you can redistribute it and/or modify
*   it under the terms of the GNU General Public License version 2 as
*   published by the Free Software Foundation.
*   Alternatively, this software may be distributed under the terms of BSD
*   license.
*   See README and COPYING for more details.
*  sertest.c
*  PURPOSE:
*   This implements a sample program for accessing the serial port.
/* ---- Include Files ---------------------------------------------------- */
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <errno.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <sys/unistd.h>
#include <pthread.h>
#include <getopt.h>
#include <termios.h>
/* ---- Public Variables ------------------------------------------------- */
int gFd = -1;
int gVal;
/* ---- Private Constants and Types -------------------------------------- */
/* ---- Private Variables ------------------------------------------------ */
struct option gLongOption[] =
    // option       A  Flag   V  (has_arg, flag, val)
    { "baud",       1, NULL, 'b' },
    { "debug",      0, NULL, 'd' },
    { "help",       0, NULL, 'h' },
    { "port",       1, NULL, 'p' },
    { "verbose",    0, NULL, 'v' },
    { 0 },
struct
    speed_t     speed;
    unsigned    baudRate;
} gBaudTable[] =
    { B50,          50 },
    { B75,          75 },
    { B110,        110 },
    { B134,        134 },
    { B150,        150 },
    { B200,        200 },
    { B300,        300 },
    { B600,        600 },
    { B1200,      1200 },
    { B1800,      1800 },
    { B2400,      2400 },
    { B4800,      4800 },
    { B9600,      9600 },
    { B19200,    19200 },
    { B38400,    38400 },
    { B57600,    57600 },
    { B115200,  115200 },
    { B230400,  230400 }
#define ARRAY_LEN(x)    ( sizeof( x ) / sizeof( x[ 0 ]))
int gVerbose = 0;
int gDebug = 0;
int gPortFd = -1;
/* ---- Private Function Prototypes -------------------------------------- */
void *ReaderThread( void *param );
char *StrMaxCpy( char *dst, const char *src, size_t maxLen );
char *StrMaxCat( char *dst, const char *src, size_t maxLen );
void  Usage( void );
/* ---- Functions -------------------------------------------------------- */
*  main
int main( int argc, char **argv )
    int         rc;
    int         opt;
    char        devName[ 40 ];
    const char *baudStr = NULL;
    const char *portStr = "ttyS2";
    speed_t     baudRate;
    pthread_t   readerThreadId;
    struct termios attr;
    // Parse the command line options
    while (( opt = getopt_long( argc, argv, "b:dhp:v", gLongOption, NULL )) > 0 )
        switch ( opt )
            case 'b':
                baudStr = optarg;
                break;
            case 'd':
                gDebug = 1;
                break;
            case 'p':
                portStr = optarg;
                break;
            case 'v':
                gVerbose = 1;
                break;
            case '?':
            case 'h':
                Usage();
                return 1;
    devName[ 0 ] = '\0';
    if ( portStr[ 0 ] != '/' )
        StrMaxCpy( devName, "/dev/", sizeof( devName ));
    StrMaxCat( devName, portStr, sizeof( devName ));
    baudRate = B0;
    if ( baudStr == NULL )
        baudRate = B9600;
    else
        int baudIdx;
        int testBaud = atoi( baudStr );
        for ( baudIdx = 0; baudIdx < ARRAY_LEN( gBaudTable ); baudIdx++ )
            if ( gBaudTable[ baudIdx ].baudRate == testBaud )
                baudRate = gBaudTable[ baudIdx ].speed;
                break;
        if ( baudRate == B0 )
            fprintf( stderr, "Unrecognized baud rate: '%s'\n", baudStr );
            exit( 1 );
    if (( gPortFd = open( devName, O_RDWR | O_EXCL )) < 0 )
        fprintf( stderr, "Unable to open serial port '%s': %s\n", devName, strerror( errno ));
        exit( 2 );
    if ( tcgetattr( gPortFd, &attr ) < 0 )
        fprintf( stderr, "Call to tcgetattr failed: %s\n", strerror( errno ));
        exit( 3 );
    attr.c_iflag = 0;
    attr.c_oflag = 0;
    attr.c_cflag = CLOCAL | CREAD | CS8;
    attr.c_lflag = 0;
    attr.c_cc[ VTIME ] = 0; // timeout in tenths of a second
    attr.c_cc[ VMIN ] = 1;  // Only wait for a single char
    cfsetispeed( &attr, baudRate );
    cfsetospeed( &attr, baudRate );
    if ( tcsetattr( gPortFd, TCSAFLUSH, &attr ) < 0 )
        fprintf( stderr, "Call to tcsetattr failed: %s\n", strerror( errno ));
        exit( 4 );
    // Put stdin & stdout in unbuffered mode.
    setbuf( stdin, NULL );
    setbuf( stdout, NULL );
    // Put stdin in raw mode (i.e. turn off canonical mode). Canonical mode
    // causes the driver to wait for the RETURN character so that line editing
    // can take place. We also want to turn off ECHO.
        struct termios tio;
        if ( tcgetattr( fileno( stdin ), &tio ) < 0 )
            fprintf( stderr, "Unable to retrieve terminal settings: %s\n", strerror( errno ));
            exit( 5 );
        tio.c_lflag &= ~( ICANON | ECHO );
        tio.c_cc[VTIME] = 0;
        tio.c_cc[VMIN] = 1;
        if ( tcsetattr( fileno( stdin ), TCSANOW, &tio ) < 0 )
            fprintf( stderr, "Unable to update terminal settings: %s\n", strerror( errno ));
            exit( 6 );
    // Kick off the serial port reader thread.
    rc = pthread_create( &readerThreadId, NULL, ReaderThread, NULL );
    if ( rc != 0 )
        fprintf( stderr, "Error creating ReaderThread: %s\n", strerror( rc ));
        exit( 7 );
    // Read stdin and send rcvd chars to the serial port
    while ( 1 )
        char    ch;
        int     chInt = fgetc( stdin );
        if ( chInt < 0 )
            fprintf( stderr, "Exiting...\n" );
            break;
        ch = (char)chInt;
        if ( gDebug )
            if (( ch < ' ' ) || ( ch > '~' ))
                fprintf( stderr, "stdin Read: 0x%02x '.'\n", ch );
            else
                fprintf( stderr, "stdin Read: 0x%02x '%c'\n", ch, ch );
        if ( write( gPortFd, &ch, 1 ) != 1 )
            fprintf( stderr, "write to serial port failed: %s\n", strerror( errno ));
            break;
    close( gPortFd );
    exit( 0 );
    return 0;   // Get rid of warning about not returning anything
*   Thread which processes the incoming serial data.
    while ( 1 )
        char    ch;
        int     bytesRead;
        if (( bytesRead  = read( gPortFd, &ch, 1 )) < 0 )
            fprintf( stderr, "Serial port read failed: %s\n", strerror( errno ));
            exit( 1 );
        if ( gDebug )
                fprintf( stderr, "Serial Read: 0x%02x '.'\n", ch );
            else
                fprintf( stderr, "Serial Read: 0x%02x '%c'\n", ch, ch );
        putc( ch, stdout );
    return 0;
} // ReaderThread
*  Concatenates source to the destination, but makes sure that the
*  destination string (including terminating null), doesn't exceed maxLen.
*  @param   dst      (mod) String to concatnate onto.
*  @param   src      (in)  String to being added to the end of @a dst.
*  @param   maxLen   (in)  Maximum length that @a dst is allowed to be.
*  @return  A pointer to the destination string.
size_t dstLen = strlen( dst );
if ( dstLen < maxLen )
StrMaxCpy( &dst[ dstLen ], src, maxLen - dstLen );
return dst;
} /* StrMaxCat */
*   Copies the source to the destination, but makes sure that the
*   maxLen.
*   @param  dst     (out) Place to store the string copy.
*   @param  src     (in)  String to copy.
*   @param  maxLen  (in)  Maximum number of characters to copy into @a dst.
if ( maxLen < 1 )
* There's no room in the buffer?
return "";
if ( maxLen == 1 )
* There's only room for the terminating null character
dst[ 0 ] = '\0';
return dst;
* The Visual C++ version of strncpy writes to every single character
* of the destination buffer, so we use a length one character smaller
* and write in our own null (if required).
     * This allows the caller to store a sentinel in the last byte of the
     * buffer to detect overflows (if desired).
strncpy( dst, src, maxLen - 1 );
if (( strlen( src ) + 1 ) >= maxLen )
* The string exactly fits, or probably overflows the buffer.
* Write in the terminating null character since strncpy doesn't in
* this particular case.
* We don't do this arbitrarily so that the caller can use a sentinel
* in the very end of the buffer to detect buffer overflows.
dst[ maxLen - 1 ] = '\0';
return dst;
} /* StrMaxCpy */
*  Usage
void Usage()
    fprintf( stderr, "Usage: sertest [option(s)]\n" );
    fprintf( stderr, "  Download a program via serial/i2c\n" );
    fprintf( stderr, "\n" );
    fprintf( stderr, "  -b, --baud=baud   Set the baudrate used\n" );
    fprintf( stderr, "  -d, --debug       Turn on debug output\n" );
    fprintf( stderr, "  -h, --help        Display this message\n" );
    fprintf( stderr, "  -p, --port=port   Set the I/O port\n" );
    fprintf( stderr, "  -v, --verbose     Turn on verbose messages\n" );
} // Usage
