Author Topic: wall avoidance  (Read 2618 times)
Offline cooldogTopic starter
wall avoidance
« on: November 12, 2007, 06:07:30 PM »
does anyone know a algorithm for a single sharp Ir wall avoidance or a tutorial
-admin
favorite web sites
http://www.societyofrobots.com/
http://www.instructables.com/
Offline Steve Joblin
Re: wall avoidance
« Reply #1 on: November 12, 2007, 06:32:17 PM »
I would mount the unit on a servo that rotates the sensor to the left side, takes a reading, rotates the sensor to the middle, takes a reading, rotates the sensor to the right side, takes a reading, then determines what action to take based on the data it just collected from the three readings.  Then continuously repeat the process.
Re: wall avoidance
« Reply #2 on: November 12, 2007, 06:37:39 PM »
OK but where can i get a algorithm for that ( i don't know how to program )
-admin
favorite web sites
Offline airman00
Re: wall avoidance
« Reply #3 on: November 12, 2007, 06:52:49 PM »
you should do tutorials on programming and learn other stuff, not just take other people's work
if you're doing that and not learning , whats the point of making a robot?
you do want to learn right???
Re: wall avoidance
« Reply #4 on: November 12, 2007, 08:31:51 PM »
the programming is pretty straight forward for the approach I suggested... what microcontroller are you using?
Re: wall avoidance
« Reply #5 on: November 12, 2007, 08:49:19 PM »
AT MEGA 8 form the $50 robot
-admin
favorite web sites
Offline Half Shell
Re: wall avoidance
« Reply #6 on: November 13, 2007, 12:45:35 PM »
A simple if statement like this:
if( irRange > 120){
  turn
Works. I am using that for my object avoidance bot right now using the Sharp IR sensor until I turn it into a mapping bot.
