Author Topic: stepper motor help  (Read 2553 times)
Offline lutherTopic starter
stepper motor help
« on: November 18, 2007, 09:01:50 AM »
hello i made a cnc router and i used stepper motor for 'x','y',and the 'z' axis, i was wondering if its possible to convert stepper motor to servo motor so i don't lose steps? i did not what to replace the stepper motors.
Offline Rebelgium
Re: stepper motor help
« Reply #1 on: November 18, 2007, 10:04:22 AM »
Have you kept in mind that servo's can only turn 180° or 90° ?
orgcrime.net
« Reply #2 on: November 18, 2007, 10:23:01 AM »
yes but ther are servo that use ecoders for 360 degree rotation
« Reply #3 on: November 19, 2007, 09:00:18 AM »
Why are your steppers skipping steps?
The reason I ask is because a DC motor with an encoder can also lose steps for the same reason . . .
Are you applying too much force on the motors?
« Reply #4 on: November 19, 2007, 04:51:49 PM »
i do not know why i lose step it seems to happen when the machine make a rapied move. i only lose a few steps because it only off by about  .015" of a inch but when it one inch thick and it has to go around 16 times  to carve through the piece of wood it make a difference.
« Reply #5 on: November 19, 2007, 05:05:46 PM »
The reason you are losing steps is because you are applying a force greater than a single step could handle. Basically the force applied is forcing the motor into the next step, which isn't good. Try slowing it all down, so that the force is lower (both dynamic and static forces).
But if its waaay too slow, or you need more force . . .
If you buy/make an encoder and put it on the stepper motor, your controller can know when a step is skipped and correct for it as a closed loop system (steppers are open loop). Or you can buy some dc motors with built in precision encoders, too . . .
« Reply #6 on: November 19, 2007, 05:12:35 PM »
 how can i put encoders on the stepper motor to make the controller know when a step is skipped and to make a closed loop system?
Offline Rebelgium
« Reply #7 on: November 19, 2007, 05:29:08 PM »
-put the encoders on the stepper (as shown on the dc motors, on the tutorial on SoR)
-measure every time the encoder rotates a bit.
-keep track of every step you send to the stepper motor
-compare them... if you see you have sent a step command, but the encoder shows the motor hasn't turned, then you know the step has been missed...
ofcourse keep in mind that 1 step is not equal to 1 encoder pulse you measure.
orgcrime.net
« Reply #8 on: November 19, 2007, 05:42:49 PM »
how do i hook the encoders to the controller
« Reply #9 on: November 19, 2007, 06:06:33 PM »
http://www.societyofrobots.com/sensors_encoder.shtml
Just literally attach your encoder output pin to a digital port pin on your controller (which controller are you using?)
And of course a common ground . . .
Make sure you read about the PID in my tutorial.
« Reply #10 on: November 19, 2007, 06:13:03 PM »
will that keep the stepper from lose steps
Offline bens
« Reply #11 on: November 19, 2007, 06:38:04 PM »
No, it will allow you to detect lost steps when they happen and correct for them accordingly.  All the encoder is doing is telling you how much your motor is turning; it's up to you to act based upon that information.
« Reply #12 on: November 19, 2007, 06:41:39 PM »
is ther anyway for the steppers to correct themself
« Reply #13 on: November 19, 2007, 08:31:41 PM »
nope - its open loop control, meaning no feedback or error correction
Last post September 05, 2007, 07:12:24 AM
Last post February 24, 2011, 09:07:31 PM
by klims
Last post August 21, 2011, 08:49:20 AM
by vbsaltydog
Last post September 29, 2011, 11:00:19 AM
by Fr0stAngel
