Author Topic: Is this a good choice for my needs?  (Read 2328 times)
Offline BajanickTopic starter
« on: November 19, 2007, 11:48:51 PM »
I have a electric wheelchair I will be using as a base for a rover. I need an Hbridge or motor controller that can whithstand at least 60 amps under normal load.
Can I get away with using this (in the link) type of solenoid for the control of the motors? I know there will be no speed control.
http://www.allelectronics.com/cgi-bin/item/SOL-80/500050/12_VDC_POWER_SOLENOID_.html
Re: Is this a good choice for my needs?
« Reply #1 on: November 20, 2007, 09:23:26 PM »
remember to search the forum
http://www.societyofrobots.com/robotforum/index.php?topic=1904.0
My blog has some info on using wheelchairs also.... erobots.blogspot.com
,Eric
P.S. The solenoid you posted is overkill for a wheelchair motor
« Reply #2 on: November 20, 2007, 10:10:42 PM »
For a heavy robot you'd definitely want speed control - otherwise the jerky motions will break stuff . . .
I quickly browsed around and found these rated at 60A and 120A:
http://www.robotmarketplace.com/marketplace_ifi_esc.html
I'm sure there are plenty more:
http://www.societyofrobots.com/robot_parts_list_electronics.shtml
« Reply #3 on: November 21, 2007, 09:45:55 AM »
i agree,
i will add speed control to my butler robot ,
without speed control its not very smooth and it does break stuff ( if things are loosly mounted..)
Offline Rebelgium
« Reply #4 on: November 21, 2007, 02:37:59 PM »
not to mention that those sudden starts reaquire huge currents...
which isnever a good thing when working with batteries. (not without batteries either for that matter  ;))
orgcrime.net
« Reply #5 on: November 22, 2007, 11:23:40 PM »
Ive seen those ifi and vantec controllers but they are pretty expensive. I know I will have a hard time with my budget.
I originally was going to use a vantec that you can hook up an RC directly to but its too much money.
I thought about the auto relays but I cant see how they could handle the startup draw and the stall current, would they?
Thanks.
« Reply #6 on: November 23, 2007, 05:52:50 AM »
The dimensionengineering.com motor drivers can also do RC input, and are much cheaper . . .
« Reply #7 on: November 23, 2007, 06:31:33 AM »
i've used automotive relays on my butler robot and they work fine .
Speed control is the best though.
Look on my blog erobots.blogspot.com
it has info and a video of a robot which uses wheelchair motors and automotive relays . I used two 12V   20Ah  batteries - -and i get a really really long lifetime per charge
« Reply #8 on: November 24, 2007, 12:20:05 AM »
I cant see how 30 amp auto relays can withstand the startup current and a stall current of 80 amps or so. When I get a chance I am going to do some tests. Ive seen the dimensions engineering site but they dont have any high current controllers.
Offline nathan25
« Reply #9 on: November 24, 2007, 12:39:05 AM »
HAve you thought about going to an old scrap yard and looking for an electric car?
you could probably find what your looking for and evn hav speed control.
I design robots to take ovr the Universe
Offline bens
« Reply #10 on: November 24, 2007, 01:01:58 AM »
You can use two 30 A VNH2SP30s to make a single 60 A H-bridge (assuming you can cool them enough for them to operate at their maximum current ratings), though that's still a little short of your 80 A stall.  The dual half-bridge configuration is described on page 14 of the VNH2 datasheet.
« Last Edit: November 24, 2007, 01:02:38 AM by bens »
Last post June 26, 2009, 03:43:27 AM
Last post November 01, 2009, 03:18:15 PM
Last post May 06, 2010, 10:44:29 PM
by rogue
Last post January 18, 2011, 09:10:28 AM
by Xtremek
