Author Topic: tiny segway ripoff  (Read 3981 times)
Offline AdminTopic starter
tiny segway ripoff
« on: November 02, 2006, 08:58:30 AM »
kinda neat to watch, in that it shows you can make a segway small and cheap
http://www.balbots.com/articles.php?tPath=12
although it seems to have a slow response rate . . .
here is the design
http://www.balbots.com/articles.php?tPath=11
Offline dunk
Re: tiny segway ripoff
« Reply #1 on: November 02, 2006, 01:44:35 PM »
the legway stands out as clever to me.
http://www.teamhassenplug.org/robots/legway/
this design is using a fairly different technique to the segway.
rather than measuring rotation like the segway they are measuring the distance of a sensor from the ground.
while this makes them far less stable on uneven surfaces the control program is far simpler.
Offline JesseWelling
  • Only You Can Build A Robot!
« Reply #2 on: November 02, 2006, 03:49:33 PM »
using a 1d gyro should be just as simple conceptualy, it just requires a trig function look up table and an extra step of calculation. Then you don't have the uneven ground problem. I would use this sensor:
http://www.sparkfun.com/commerce/product_info.php?products_id=698
Being able to read 500 degrees a second should be good enough to catch a fall. If you do the math it means that th1at your bot could fall over (from standing up) in .18 seconds (1second/500degrees = .002seconds per degree) and you wouldn't be able to catch it quick enough. This is ofcourse dependent on analog coversion time as well. I did some off hand tests and a pen takes at least 1/2 a second to fall over from straight up....anyone want to make a segway?
Offline dunk
« Reply #3 on: November 02, 2006, 04:25:37 PM »
so i played around with an angular rate sensor at one point, trying to make my own balancing bot.
it's harder than you would at first think.
the angular rate sensor doesn't tell you which way up is but instead tells you how fast it is rotating.
(an accelerometer will tell you which way is up but only if it's not accelerating.)
so to initially calibrate the angular rate sensor you have to hold the bot stationary. this will give you a set output voltage.
if the bot starts to rotate (ie, fall over) this voltage will change.
you have to develop an algorithm that takes into account the rotation of the robot and also the speed at which the wheels are turning.
to get the bot balancing in a stationary position you have to react to any change in angle by turning the wheels in a direction that counters that angle.
if the rate of change of angle is increasing you need to turn the wheels faster. if the rate of change of angle is decreasing you need to turn the wheels slower. if the rate of change of angle is constant then your bot is not falling over at the moment but it is not necessarily stationary.
you have to be take into account the speed the wheels are turning at the moment and try to add just the right extra speed to hit the stationary *and* balanced point both at once.
to anyone who's trying to build a balancing bot, remember it's actually easier to balance a top heavy item than a light one.
to prove this point, try and balance a broomstick on it's end in your hand.
it's easier with the heavy end pointing up.
i never did get this idea for a bot working particularly well.
it could stay upright but you wouldn't call it "balancing". more like a jittering shuffle.
i never did work out if the problem was due to lack of precision in the sensor i was using, interference from the motors or just problems with my code.
most of the articles you find on the internet (as well as the segway) use a combonation of angular rate sensors and accelerometers.
i started my experiment thinking it was possible with just the angular rate sensor but i never did prove this point effectively.
i'll probably go back to it one day but my present bot is taking up all my spare time.
« Reply #4 on: November 02, 2006, 05:05:55 PM »
sounds like a multilevel PID or fuzzy controller could work out ok
Last post February 14, 2009, 11:05:19 PM
by cooldog
Last post March 31, 2009, 03:30:20 PM
by Rebelgium
Last post April 08, 2010, 11:24:09 AM
by JoeSkull
Last post October 03, 2010, 02:23:32 AM
by Xyver
