Author Topic: will this work (now with pics)  (Read 3531 times)
Offline ed1380Topic starter
« on: November 23, 2007, 06:39:17 PM »
so I'm building this http://www.popsci.com/popsci/how20/ddb6bb1fd9ca4110vgnvcm1000004eecbccdrcrd.html
it calls for usb for power. got that.
but needs serial (db9) and ttl->rs232 for data.
so instead of doing GPS->rs232 converter->DB9->usb converter->PC
I want to do GPS->USB->PC
will this work http://www.acroname.com/robotics/parts/S22-USB-SERIAL-INT-CONN.html
or this http://pdncons.com/mm5/merchant.mvc?Screen=PROD&Store_Code=PDNCONS&Product_Code=A-USBToTTL&Category_Code=SERIAL
thanks guys
EDIT- will it work with vista
« Last Edit: December 28, 2007, 06:53:50 PM by ed1380 »
Offline frank26080115
Re: will this work
« Reply #1 on: November 23, 2007, 07:42:02 PM »
Re: will this work
« Reply #2 on: November 23, 2007, 08:07:12 PM »
thanks.
and even better cause i already have a usb A to usb A cable
only piece of concern I have is- it's set for 3.3v and the gps module needs ~5v. do I just take an extra set of wires from the plug and send it to the module?
will I need to solder the jumper?
usb can handle 500mA right? google sucks
Re: will this work
« Reply #3 on: November 23, 2007, 08:14:56 PM »
just take the 5V from the USB line and ignore the 3.3V pin.
the first hit on my google search got this:
http://www.usbpluspower.org/
yeap, 500mA
(I don't think it was google that was sucking :P)
j/k!
Re: will this work
« Reply #4 on: November 23, 2007, 08:58:58 PM »
what else do I need to consider? what am I overlooking?
thanks admin. I searched for like 5 minutes in google and couldn't find anything
« Last Edit: November 23, 2007, 08:59:37 PM by ed1380 »
Re: will this work
« Reply #5 on: November 23, 2007, 11:36:17 PM »
ok. some more questions/complications
1- it says if I unsolder the jumper I can do 5v IO. to where do i connect the output if i want 5v IO? just the 5v line from the usb cable
2- the author of the article did GPS->rs232 converter->DB9->usb converter->PC. Why? is it necesary for it to work?
3- Will attached pic work?
Re: will this work
« Reply #6 on: November 24, 2007, 08:55:09 AM »
just ignore that 3.3V line entirely. Solder a wire to the 5V on the USB to connect to your other electronics, and do not solder it to the 3.3V line.
each of those devices use a different signal, and so the converters change the signal. using this TTL to usb converter you bipass the rs232 signal. rs232 is the old way of doing things, so people still occasionally do it.
don't connect anything to the 3.3V line, and then it will work
Re: will this work
« Reply #7 on: November 24, 2007, 10:11:58 AM »
ok. so like this? (atached pic)
there is RXD1, RXD2, TXD1 on the GPS module. RX, TX on the converter. what gets connected to what? cause what I drew is diferent from what the author did.
Re: will this work
« Reply #8 on: November 24, 2007, 10:53:16 AM »
yea, the power is correct.
you'd have to look up/read the gps datasheet to be sure where everything goes . . .
without looking up your gps datasheet, i think you got the tx/rx connections wrong.
you want the output tx on the gps to connect to the input rx of your usb board . . .
Re: will this work
« Reply #9 on: November 24, 2007, 11:40:58 AM »
the left half of the pic is from the datasheet.
so RX gets connected to TX and vice versa.
I guess I'm off to order the stuff
Re: will this work
« Reply #10 on: November 24, 2007, 12:15:59 PM »
On the USB to serial module, the pin labeled VCC is 5V, top right of the image
« Last Edit: November 24, 2007, 12:16:43 PM by frank26080115 »
Re: will this work
« Reply #11 on: November 24, 2007, 06:33:39 PM »
o yeah. I'm so stupid.
should I get a plastic or aluminum project box from Radioshack. will the aluminum be effective at all with helping eliminate RF inteference?
Offline paulstreats
  • Helpful? 20
Re: will this work
« Reply #12 on: November 25, 2007, 08:28:47 PM »
i would personally go for a plastic box, since its likely to be more durable and you dont have to worry so much with shorting your board if it touches any metal.
I dont think aluminium would stop interference that much, you would want something more conductive such as copper.
if you use the plastic box, maybe you could make a copper wire grid around the inside maybe 0.5 cm apart like this
connect the grid to ground and it should stop interference.
it would stop waves getting through just like the holes in your microwave door are just small enough not to let the microwaves pass through. because you want to stop larger waves you can have a larger spaced grid.
Re: will this work
« Reply #13 on: November 25, 2007, 08:44:39 PM »
k. thanks.
that seams like too much work.
Re: will this work
« Reply #14 on: November 25, 2007, 08:46:24 PM »
Interference from what?
Re: will this work
« Reply #15 on: November 25, 2007, 08:59:41 PM »
its gonna be in a car.
so the BIG V8  8)  :D   (spark plug wires have high voltage in them)
seriously- AC blower motor, radio, speakers, IDK othe electronics
Offline paulstreats
  • Helpful? 20
Re: will this work
« Reply #16 on: November 25, 2007, 09:06:27 PM »
any sized grid will work from main electric interfercence....
Offline bens
Re: will this work
« Reply #17 on: November 25, 2007, 09:06:55 PM »
I don't think you'll have to worry too much about RF interference.
Re: will this work
« Reply #18 on: November 25, 2007, 09:34:24 PM »
I'm so stupid.
It came in a tin box for rf protection, and aready had a 10 pin female header
its from an onstar box from a GMC yukon
« Last Edit: November 25, 2007, 09:35:49 PM by ed1380 »
Offline paulstreats
  • Helpful? 20
Re: will this work
« Reply #19 on: November 25, 2007, 09:43:26 PM »
its amazing that there are all of those chips on the board, and they only provided protection for a specific part
Re: will this work
« Reply #20 on: November 25, 2007, 09:58:36 PM »
umm not really. I just took apart the whole module, so all you see in the pcb.
it's surrounded by about 1/16" of sheet metal
Re: will this work
« Reply #21 on: December 15, 2007, 01:09:40 PM »
i just noticed that the breakout board might have a mini usb plug. good thing caues I dont have one
Re: will this work
« Reply #22 on: December 28, 2007, 11:35:00 AM »
WOOT triple post  :P
i built it and it works
I'll get some pics up ASAP
Re: will this work (now with pics)
« Reply #23 on: December 28, 2007, 06:54:28 PM »
quadpost  :o
LOL 7.5hours ASAP
« Last Edit: December 28, 2007, 06:56:19 PM by ed1380 »
Last post February 18, 2009, 04:07:22 PM
by ZacAttack
Last post July 27, 2009, 11:24:38 AM
by Trumpkin
Last post November 03, 2009, 11:07:10 PM
by SmAsH
Last post March 07, 2010, 03:03:17 PM
by little-c
