Author Topic: New robot kit Mongoose, what do you think?  (Read 3263 times)
Offline blueroomelectronicsTopic starter
« on: November 24, 2007, 12:03:37 AM »
Here's a photo and a 3D drawing, would like to hear any comments you have.
http://www.blueroomelectronics.com/
Junebug PK2 programmer / debugger / lab connected to a Mongoose
3D Sketchup drawing showing some internal details
« Last Edit: November 24, 2007, 12:06:54 AM by blueroomelectronics »
Smart Kits build Smart People
Offline nathan25
Re: New robot kit Mongoose, what do you think?
« Reply #1 on: November 24, 2007, 12:06:36 AM »
It's really just an advanced verison of the 50$ robot... tho it still is really cool...
I design robots to take ovr the Universe
« Reply #2 on: November 24, 2007, 12:10:01 AM »
Doesn't the $50 robot cover only the chassis, wheels & motors? I was under the impression the controller adds a significant cost to that design.
Edit: Ahh that $50 robot  :) the cardboard wheels one it's pretty neat.
IMHO I've got a Parallax BOE BOT and I'm not fond of modified servos for drive, they're require a pulse just to run. I've used the hardware PWM in the 18F2525, easy to get accurate speed control.
Mongoose with standard 2x16 LCD and concept breadboard expansion
« Last Edit: November 24, 2007, 12:24:10 AM by blueroomelectronics »
Offline nathan25
« Reply #3 on: November 24, 2007, 12:24:14 AM »
Not really the chasis is made outta cardboard  :P
a water bottle, or anything else u can get your hands on that will keep the servos appart from each other. and you are practiclly building the carrier board for yourself.
You know what you shoud add to the mongoose...
tri-spoke wheels...
this way the robot will be able to climb over steps.
I saw it on the discovery channel... they had built a 6-wheeled robot...based on a cochroach... it was really neat.
well thats my two cents into it
nate
the pic might not turn out... but think of them as a peace symbol with the circle cut out half way on one half of the V thingy... all the way around
um like thing
                              |____\
                          /___
that probably gives the idea
« Last Edit: November 24, 2007, 12:28:28 AM by nathan25 »
Offline nathan25
« Reply #4 on: November 24, 2007, 12:31:13 AM »
me either i cant stand it it just means alot more programing... thats why for my LRNS (Logical Robotic Navigation System) I'm using the Sabertooth 2x5 motor controller.
« Reply #5 on: November 24, 2007, 12:34:37 AM »
Cool, as for tri spoke wheels the wheels on the Mongoose are Tamiya 58mm Narrow wheels, they're not that expensive, look nice and work great.
As for stairs the Mongoose is too small, only 58mm high
That Sabertooth 2x5 looks nice but it's $59, a L298 can handle almost as much current and is much cheaper. You still need something to control either of them.
« Last Edit: November 24, 2007, 12:39:28 AM by blueroomelectronics »
Offline nathan25
« Reply #6 on: November 24, 2007, 12:37:17 AM »
i was on your site earlier, what does the firefly do?
« Reply #7 on: November 24, 2007, 12:41:09 AM »
Firefly is a ZIF socket adapter for PICs, it's also a 16F88 demo / tutor. You need an ICD like the Inchworm or Junebug kits to use it.
Offline nathan25
« Reply #8 on: November 24, 2007, 12:42:43 AM »
ah...sounds interesting, can it be sum how wired into a autonomous rover? what does it control?
« Reply #9 on: November 24, 2007, 12:52:34 AM »
The Firefly is designed as a PIC programming companion, aside from the Mongoose I have no other kits designed for Mechatronics.
Offline maverick monk
« Reply #10 on: November 24, 2007, 05:09:41 PM »
not sure id like to have my expencive circut board facing out on the front of the bot... a cover for it might be a good idea, like a pvc/plexiglass plate
Offline Rebelgium
« Reply #11 on: November 25, 2007, 10:04:31 AM »
True, if that is the front ofcourse, because i'm not sure.
Is there a caster ? What sort is it?
I like the compactness of the mongoose, you can see it has been designed efficiently. (eg: the placement o.t. battery holders, etc.)
All I would recommend is to add bumpers and protection.
and you could make them touch sensitive too...
orgcrime.net
« Reply #12 on: November 26, 2007, 12:49:41 AM »
The front has the circuit board, there are four spacers and a I/O connector facing forward designed for mounting user made expansion PCBs like line followers, range finders, bumpers, etc. The front mounted PCB also mounts the rotation sensors.
This leaves the top available for breadboarding and other projects.
The rear ball caster and most of the mechanical parts are all high quality Tamiya kits.
