Author Topic: better proximity sensor  (Read 1949 times)
Offline s80ts0465Topic starter
« on: November 27, 2007, 08:40:37 AM »
I'm thinking about to use the proximity sensor to create an autocharing robot.
My intention (suggested from many articles i've found on the net) is to use an IR TX from the charging station and an IR RX on the robot.
I've read many different configuration that are possible to implement, but i'd like to know which is the best configuration you've tryed and actually using.
I'm oriendted to the Panasonic PN4602 as receiver.
So what is your prefered configuration??
Bye Ste
Offline Robotboy86
Re: better proximity sensor
« Reply #1 on: November 30, 2007, 10:54:13 AM »
well you could mimic the current techonology in modern avionics.
http://www.faa.gov/about/office_org/headquarters_offices/ato/service_units/techops/navservices/gbng/ils/
thats a pretty good explanation of what it is.  Although instead of trying to do this with expensive technology you could use two IR beacons on the station, and a simple IR camera on the robot.  Almost exactly like the Wii's remote control and its sensor bar..
when it finds the proper two IR beacons(or 3,4 whatever) it simply sets up a course to them and scootches on in.  Now one of the problems with IR is that its suspectible to background noise..  candles, sun, some flash lights, that kinda stuff can ruin IR..  or at least give you false positives.  False positives are easy enough to counter with light patterns.  Set the IR led's to flash in certain patterns. Like 1, 4, 2, 3, 1, 4, 2, 3, etc etc(assuming 4 led's are used) and set the robot up to recongnize this.
« Reply #2 on: November 30, 2007, 12:27:42 PM »
http://www.schursastrophotography.com/robotics/beac1.html
and you should make something like this
What is your budget?
« Reply #3 on: November 30, 2007, 12:50:36 PM »
The price isn't a problem.
I've already read the article of Pammi and i think i'll realize it. It seems a easy, cheap and working system.
So i'd use 2 PNA4602 and 1 IR led.
Do you maybe know which are the negative side of this system?and how to solve them?
Ste
« Reply #4 on: November 30, 2007, 01:21:57 PM »
Well the problems that I see is sunlight will mess up the IR  and that there has to be an open path between the base and the robot - other wise the IR light gets blocked.
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
« Reply #5 on: November 30, 2007, 01:30:57 PM »
Sunlight comes in from windows. Just install the station in the opposite corner of the room.
True, but the robot should have wheel encoders and at least try to track it's wereabouts. There should also be a "find the charger routine" that would move the robot towards large open spaces and search for the beacon.
« Reply #6 on: December 01, 2007, 01:10:09 AM »
that's not a problem for me, my robot will be used in an no window tunnel ::)
Last post June 28, 2009, 05:46:16 AM
by SmAsH
Last post March 15, 2010, 11:42:01 PM
by Pratheek
Last post November 18, 2010, 09:53:05 PM
by Redcap
Last post July 08, 2011, 07:13:16 PM
by billhowl
