Author Topic: IR LED setup@ 6V  (Read 3034 times)
Offline airman00Topic starter
IR LED setup@ 6V
« on: December 02, 2007, 09:47:57 AM »
I am currently using this setup with my IR reflective sensor http://www.superdroidrobots.com/product_info/qrb1134.htm
Now I want to switch from 5V to 6V
There are two resistors which I am unsure what value they should have:
There is a 220 ohm resistor going to one IR LED and a 10K ohm resistor acting as a pull up resistor.
Those values were meant for 5V , but what values should they be at 6V???
Thank You
Offline bens
Re: IR LED setup@ 6V
« Reply #1 on: December 02, 2007, 04:54:21 PM »
You don't need to change your resistor values.  Your IR LED will be slightly brighter, but that's not a big deal.
« Reply #2 on: December 02, 2007, 05:34:57 PM »
Thanks, I did a test on my own , and the IR leds were fine
how do you calculate the LEDs proper resistor?
Offline ed1380
« Reply #3 on: December 02, 2007, 06:54:13 PM »
Offline bens
« Reply #4 on: December 03, 2007, 03:04:07 AM »
And here's another site: http://home.cogeco.ca/~rpaisley4/LEDcalc.html
In general, you want a few milliamps (maybe 2 - 20 mA?) running thorugh your LED.  The higher the current, the brigher the LED will be, but the faster it will burn out.  To calculate the current passing through your LED you can use Ohm's Law: I = (V - LED voltage drop)/R
Typically LEDs have a voltage drop of between 1 and 3 V, depending on their color (the higher the energy of their color, the bigger the voltage drop).  As long as you're in the low milliamp range, you can always try a current and see how bright your LED is (assuming it's visible and not IR, of course), then adjust the resistor accordingly if it seems too bright or dim.
Offline ed1380
« Reply #5 on: December 03, 2007, 03:18:51 PM »
yep up to 20mA for regular led's, but I have this super bright one that uses 30  ;D
« Reply #6 on: December 04, 2007, 10:59:19 AM »
http://www.societyofrobots.com/electronics_led_tutorial.shtml
You can also use ohm's law given the known current and resistance for the old voltage, then recalculate resistance for the new voltage.
Last post September 23, 2008, 05:47:18 AM
by Ro-Bot-X
Last post March 09, 2009, 04:49:19 AM
Last post April 10, 2009, 12:12:41 AM
Last post May 08, 2009, 01:40:42 PM
by offy
