Author Topic: best overall microcontroller  (Read 9430 times)
Offline Mega
Re: best overall microcontroller
« Reply #30 on: December 13, 2007, 02:56:22 PM »
http://itp.nyu.edu/physcomp/Labs/Servo
Connections are similar for multiple servos.
Visit my robotics blog at http://megabotblog.blogspot.com/
Offline Spoil9
« Reply #31 on: December 13, 2007, 04:32:01 PM »
airman00-
I would like to stay with BASIC, but do not want to pay for the Stamp. So I figured I will use C.
Knowledge is Power. Power Corrupts. Study Hard. Be Evil.
Offline Spoil9
« Reply #32 on: December 13, 2007, 06:01:58 PM »
When looking at the AVR, it says that the 'Boot Logger' software is already programmed. What does this mean?
« Reply #33 on: December 13, 2007, 06:15:16 PM »
airman00-
You could use PICBASIC with any PIC microcontroller
but picbasic costs 100 bucks ( however I downloaded it from a torrent website .... ;))
I recommend PIC BASIC
Offline JesseWelling
  • Only You Can Build A Robot!
« Reply #34 on: December 13, 2007, 08:54:26 PM »
This most likely means the boot loader. It's a program that is always on the chip that makes getting your programs onto the chip easier.
So instead of having to use fancy JTAG equipment, you will most likely need a regular serial port. It's a GoodThing but you will want more information about it obviously.
Which AVR is this btw? I use a Robostix (which is an ATmega128, which is to say an AVR) hooked to a Gumstix and I use the I2C (a more specialized kind of serial protocol) to send my boot loader things and it works out all right.
Offline Spoil9
« Reply #35 on: December 14, 2007, 12:11:34 PM »
Yes, Boot Loader. My bad.
I do not remember where I saw it but it was in another post on this forum and I just wasn't sure what it was.
If I can use PIC BASIC with PIC's, then that is something I am going to look into more as I have no real disere to get into programming as I more perfer the electronics aspect of robotics.
The $100 is not bad for PIC BASIC... but what all does that include? I'm assuming that is just a compiler (but hoping that it's a good one).
Does anyone else have any oppionions on PIC BASIC for simple programming?
(By simple I mean that I am not going to try to use it to program AI, nor speech releated, etc. Just a "If this happens, then do this. If that happens, then do that" sort of programming.)
Thanks to all.
- Bill
« Reply #36 on: December 14, 2007, 12:44:23 PM »
Compiler  - http://www.melabs.com/products/pbc.htm
Programmer I use http://www.melabs.com/products/usbprog.htm
PICBASIC is actually pretty complex for the BASIC language http://www.melabs.com/products/pbcis.htm
I personally use PICBASIC Pro, its $250 , but its amazing ! Much more commands and more complex
also, PICBASIC allows you to add assembly code within the BASIC code
Actually, I've seen numerous projects using PICBASIC for speech recognition, AI, and camera equipped robots.
Offline TrumpkinTopic starter
« Reply #37 on: December 15, 2007, 02:58:21 PM »
It sound like AVR is a ton cheaper than pic, right? Doesn't the pic compiler cost like $100?
Robots are awesome!
Offline Mega
« Reply #38 on: December 15, 2007, 03:06:02 PM »
That's exactly I started with AVR (Arduino to be more specific), it's cheap and fairly easy which makes it a great start of a journey through the world of robotics. ;)
Offline paulstreats
« Reply #39 on: December 15, 2007, 03:24:11 PM »
and the rest.....
http://www.htsoft.com/purchase/pricelist.php
Offline Spoil9
« Reply #40 on: December 15, 2007, 06:45:39 PM »
This may be just my opnion, but it seems like all MCU's are about the same price. It just depends on wether you pay for the chip or for the compiler or the extra hardware, but in the end I think they all come out about the same.
« Reply #41 on: December 15, 2007, 07:18:04 PM »
MCUs do cost the same
Compilers and programmer hardware are the ones that cost money
For PIC mcu the compilers and hardwares cost a lot and for the AVR they are much cheaper
s
But, PICs are easier to get ( free samples while AVR is no longer sample) and there is a wider variety of PICs which are suitable for different tasks.
AVR does not have that wide of a selection
My vote is for PIC micro controllers with PICBASIC compiler
