Author Topic: Maxbotic EZ1 Sonar Sensor  (Read 3913 times)
Offline JesseWellingTopic starter
  • Only You Can Build A Robot!
« on: November 07, 2006, 07:31:20 PM »
I'm having some trouble with the MaxBotix EZ1 sonar...any one ever use it?
Here is the web page: http://www.maxbotix.com/
I can use the analog ok but it's possible for me to use the serial.
I know my serial code works on my AVR but I keep getting junk
out of this thing. Any one ever use the Serial option on it?
Thanks for the help
Offline dhylands
Re: Maxbotic EZ1 Sonar Sensor
« Reply #1 on: November 17, 2006, 05:41:52 PM »
Hi Jesse,
The serial on the Maxbotics isn't really logic level serial. True, it does use logic levels, but it uses them in a way that allows a PC to be plugged in directlly. You have a couple of options to connect it to your AVR.
1 - Invert the Tx and Rx lines (using a hardware inverter).
2 - Stick a Max232 or similar between the maxbotix sensor and the AVR (treating the maxbotix sonar like an RS-232 level device).
I wrote up a page over here:
http://docswiki.gumstix.org/Serial_voltages
which explains the differences between the various voltages. The maxbtox sensor is behaving like a device which uses "logic level RS-232".
Dave Hylands
Vancouver, BC, Canada
http://www.DaveHylands.com/
« Reply #2 on: November 17, 2006, 07:58:16 PM »
Yea I ordered in some level shifters in and am working it out this weekend.
Last post January 20, 2008, 12:25:48 AM
by SmAsH
Last post November 04, 2008, 07:13:13 PM
by paulstreats
Last post November 21, 2008, 04:27:23 PM
by Rebelgium
Last post September 11, 2011, 07:24:19 AM
by doly77
