Author Topic: $50 line following robot (working).  (Read 2900 times)
Offline JoseS13Topic starter
« on: December 10, 2007, 07:58:34 PM »
Well I started this project as a photovore and ended up with a line follower. I used the same code as the photovore but instead of using the photo resistors I used two QTI IR sensors http://itp.nyu.edu/physcomp/sensors/Reports/QTILineSensor. I had to use a 10kohm resistor on each sensor for them to work with the program (check link for reference). I also changed the threshold value in the source code from 8 to 50. It works like a dream. I'll post a video of the robot later. The robot follows a Black line on a white surface.
Thanks admin for the wonderful tutorials and this great forum. I had to build this project for class and would not have been able to finish if it wasn't for all the useful information on your site and forum. Im finishing my electronics major this week and don't know crap about C language. Well I learned a little from experimenting with your codes.
Thanks,
Jose
 ;D
« Last Edit: December 10, 2007, 08:07:23 PM by JoseS13 »
Re: $50 line following robot (working).
« Reply #1 on: December 10, 2007, 08:10:40 PM »
 :D
Offline airman00
« Reply #2 on: December 10, 2007, 10:09:42 PM »
Just curious,
the robot cannot do sharp turns ( more than 60 degree turns)  and 90 degree turns are out of the question
cant wait to see the video
« Reply #3 on: December 10, 2007, 10:47:44 PM »
I didn't test how sharp it could turn yet. I have to show it in front of the class Wed. I guess that will be a good time to find out. Those sensors are only 6 dollars a pop from Parallax.
« Reply #4 on: December 11, 2007, 05:55:54 AM »
If you want it to do sharp turns, just change the servo speeds to be faster when it turns.
Offline airman00
« Reply #5 on: December 11, 2007, 09:11:22 PM »
oh heres a line following / object avoiding robot i built
its a bit crude but I'm redoing it out of plexiglass next week.
Last post January 25, 2008, 01:01:12 PM
by javafiend
Last post June 15, 2008, 09:20:36 PM
by koolboarder007
Last post July 20, 2008, 06:47:55 PM
by pomprocker
Last post April 02, 2009, 10:15:34 PM
by robotmir
