Author Topic: Modifying Servo SG5010 BB Standard  (Read 5667 times)
Offline reSpawnTopic starter
« on: December 11, 2007, 02:50:52 PM »
Hello! I want to buy 4 servos from a local shop(in my country..) called "Servo SG5010 BB Standard". You can see its specs here:
http://sierra.ro/Servo-SG5010-BB-Standard-p609p.html
Voltage: 6 V
Momentum(I belive): 6.5 kg-cm
Speed: 0.16 sec/60°
Does someone know how to modify this servo for continuous rotation, or is it the same process as for Admin's servo?
Btw, the price for one is 11.29$.
Cheers,
reSpawn.
« Last Edit: December 11, 2007, 03:07:36 PM by reSpawn »
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Re: Modifying Servo SG5010 BB Standard
« Reply #1 on: December 11, 2007, 03:08:48 PM »
I have pictures of it's gears and instructions on how to modify it.
« Reply #2 on: December 11, 2007, 03:13:11 PM »
well, can you please post them here? or make an instructable on how to modify them? :)
Cheers,
Nicu.
Offline arch.bishop
« Reply #3 on: July 09, 2008, 02:16:59 AM »
Hey, can you send me a info how to mod a servo SG5010? Thx
« Reply #4 on: July 09, 2008, 10:34:11 AM »
its not metal geared so you can probably modify it the same way as a regular servo
Offline Ro-Bot-X
  • Helpful? 25
« Reply #5 on: July 09, 2008, 06:47:34 PM »
The SG5010 servo internal is like a Futaba servo, or GWS servo. It has a little piece of plastic that connects the pot axle to the spline gear. All you need to do is remove that piece, cut perfectly the stop on the spline gear and use ONE drop of Superglue to fix the pot in place when the motor stops spinning (using a 1.5ms signal, rotate the pot until the motor stops spinning).
MAKE SURE you don't spill glue on the ball bearing!
Here are some pictures of the gears and the piece you need to remove:
- in the first picture you see the black piece on top of the ball bearing,
- in the second picture you see it removed,
- in the third picture you see the stop allready cut:
« Last Edit: July 09, 2008, 06:49:14 PM by Ro-Bot-X »
Offline ktz
« Reply #6 on: April 28, 2011, 09:14:50 AM »
Hi everyone!  I'm hoping to bring this thread back from the dead as I have just been through this tutorial and have run into issue getting the motor to change directions.
Im using Arduino to control it. As per instructions above, I rotated the potentiometer until the motor stopped moving and when fed a position of "0", it stops moving.  Any other number turns the motor counter clockwise.
Does anyone have any pointers on how I might be able to get this motor moving clockwise as well?
Thanks for any help in advance!
ps - (by the way I did spill super glue on my bearing and spend hours cleaning it...anyone attempting this process should make sure they remove the bearing before glueing the potentiometer in place).
Offline ktz
« Reply #7 on: April 29, 2011, 08:59:14 AM »
well...i figured it was a long shot...the thread was well over 2 years old.
Anyhow, I sorted it out...apparently I needed to write "90" to the servo (to center it), and THEN adjust the internal pot until it stopped moving.  Did so and it's all good now!
Last post January 17, 2008, 05:16:42 PM
by SeagullOne
Last post January 26, 2008, 01:08:18 PM
Last post September 01, 2008, 03:44:39 PM
Last post February 10, 2010, 01:26:35 AM
by farsam1984
