Author Topic: $50 Robot: 8MHz clock makefile  (Read 1867 times)
Offline SomeSabaTopic starter
« on: December 11, 2007, 07:25:11 PM »
Hello,
I am using an Atmega168, and i happen to be sending serial data with the UART too.
In the new UART tutorial, Admin changed the clock speed from 1MHz to 8Mhz (via Ponyprog i think), and i also need to do this. A while ago i accidenly messed with the fusebits and i was locked out of my mega168, so i dont want to make the same mistake, but i use avr-gcc and i cant get pony prog to work.
So i have to actually type in the hex code for the fuse high and low bytes to get what i want, which scares me because i know ill mess up. So i was wondering if ponyprog makes a makefile that sets the fusebits everytime you program it, if so, can anyone send me their makefile for the 8Mhz clock?
If not its okay, <3, thank you for your time!
Re: $50 Robot: 8MHz clock makefile
« Reply #1 on: December 14, 2007, 11:30:36 PM »
Nevermind!
I dont need the makefile anymore,
I was planning on controlling my motors with serial command, and i set everything up (at 1MHz), i doubled Tx to get .2% error with 9600buad and ran my code. It was horrible, i spent 2 full days tweaking, changing back and forth to 2400 buad, nothing was working like it was suppose to, the left motors would run forward when i comanded the right motors to go reverse!  ???.
Then i came to the conclusion that the serial was for some reason unreliable and switched my controller to PWM mode, i setup a timer0, and now it works perfectly!
Thank you!
« Reply #2 on: December 15, 2007, 10:31:57 AM »
Sorry I wasn't able to help.
I played around with PonyProg for about 20 minutes back when you first posted this and wasn't able to figure out how to change the clock divisor for you. I spent quite awhile googling for it too.
I guess software is the only way for now . . .
If anyone figures it out, let us know.
Last post May 13, 2009, 03:42:30 PM
Last post July 15, 2010, 04:19:54 AM
by pilot_error
Last post December 02, 2010, 10:35:20 AM
by Crunchy Theory
Last post March 24, 2012, 08:13:40 PM
by mtnj356
