Author Topic: gcc plug-in: Error  (Read 2049 times)
Offline rox2007Topic starter
gcc plug-in: Error
« on: December 12, 2007, 01:09:37 AM »
i am new to designing and implementing robots. i found your tutorial very interesting and decided to impliment it. although when i try to build the code i get this error
gcc plug-in: Error: Object file not found on expected location D:\robot\Photovore_v1.elf
Make sure your makefile specifies the output .elf file as Photovore_v1.elf
could you help me out
thank you
Re: gcc plug-in: Error
« Reply #1 on: December 12, 2007, 07:50:58 AM »
I suspect you didn't properly setup the Makefile.
Do this:
Check the box that says 'Use External Makefile' and then browse to locate the makefile (the file in the downloaded source code labeled 'makefile'). Then push OK.
Also, make sure all your files were properly put into your folder D:\robot\
« Reply #2 on: December 12, 2007, 10:39:39 AM »
thank you
Last post December 26, 2008, 08:29:22 PM
by Webbot
Last post July 18, 2009, 09:19:29 PM
by mdmedlin
Last post June 19, 2012, 07:34:17 PM
by Proctor
Last post June 15, 2010, 08:09:10 AM
