Author Topic: New RC robot project  (Read 8714 times)
Offline garriwilsonTopic starter
« on: December 16, 2007, 10:17:54 PM »
Hello, I'm planning yet another project. (are you getting pissed because I keep changing and just gather information from you without using it?)
It will be (might be if I actually decide to make it) like a tank with a webcam on top.
Here are the things I want to buy:
1. http://www.budgetrobotics.com/shop/?shop=1&cat=51&cart=533785 (base-chassis)
2. http://www.allelectronics.com/cgi-bin/item/JS-6/search/6-CHANNEL_TRANSMITTER_AND_RECEIVER_.html
   This will be the radio system. However, it says in the note that you need to use a microcontroller module to      separate the channels (do I have to do that?)
3. http://servocity.com/html/spt100_pan___tilt_system.html (to hold and move the webcam)
   For the pan and tilt I need two servos. I have two HS-311s at home but they are continuous rotation. Will those work? I believe it will work for the horizontal pan but not the tilt right?
4. A webcam I already have (I have a question about sending the footage to a computer, it is at the below).
OK, question about webcam: how do I make the webcam send the live footage to a computer but wirelessly? Will that cost a lot? Or should I just buy a wireless webcam? I don't want to buy a new one because I already have a $40 one.
If there are any contradictions please notify me. Thank you.
« Last Edit: December 17, 2007, 11:32:48 AM by garriwilson »
Re: New RC robot project
« Reply #1 on: December 17, 2007, 11:33:46 AM »
By the way, my budget will be about $200.
Offline airman00
« Reply #2 on: December 17, 2007, 02:06:53 PM »
OK, wireless cams to the internet cost much $$$. What you might be able to do is to either use Zigbee or maybe have a regular RF camera and then connect the output to a laptop's videocard
Or , maybe just use wireless USB hubs or just bluetooth USB hubs.
All of the above interfaces can be bought online and also they could be made by you as well.
Offline JonHylands
« Reply #3 on: December 17, 2007, 03:08:46 PM »
You really don't want to use continuous rotation servos for tilt or pan. You really can't pan the camera all the way around, unless the camera has a built-in battery and is wireless, and you put the tilt servo below the pan one. Otherwise, the wires will just get twisted up...
- Jon
« Reply #4 on: December 17, 2007, 04:15:02 PM »
definitely the easiest way . . . have you tried ebay?
so to transmit camera data requires a lot of bandwidth . . . probably easier to just use a CMUcam/AVRcam, or put your laptop on your robot . . . you can get a ipaq or some other handheld computer that has a webcam driver, too.
« Reply #5 on: December 17, 2007, 09:30:19 PM »
I mean I could get this but I think it's a little pricey. Is $90 pricey in the world of these:
http://servocity.com/html/2_4ghz_color_video_system.html
« Reply #6 on: December 17, 2007, 09:38:57 PM »
Thanks to this post by gshoger, (http://www.raidentech.com/miwicocaspyc.html), I found out about this:
I need to know if:
1. I can apply my pan and tilt system I listed above to this
and
2. How do I plug it into my computer or TV?
Offline airman00
« Reply #7 on: December 18, 2007, 05:37:57 AM »
I need to know if:
Why not?
I have the same type camera. To connect to a TV you just plug the RCA plugs from the reicever into the TV. TO connect to the TV you need a RCA to USB capture hardware
http://www.brickhousesecurity.com/ad02a.html
Offline ed1380
« Reply #8 on: December 18, 2007, 07:19:27 AM »
youd need to buy teh transmitter/camera and the receiver
look at sparkfun they had a small wireless cam, and someone posted one like sparkfun's but cheaper. sry couldnt fint it
« Reply #9 on: December 18, 2007, 11:36:43 AM »
Oh sorry, wow I didn't notice there were two separate parts. Crazy prices!
Why not?
How would I attach it? Isn't it like a circuit board?
And for the HEX Radio system, is the microcontroller channel separator difficult to make? Could I use my $50 dollar robot board? Thanks
So, I have to get the 100$ cable??? No way Jose! LOL
« Reply #10 on: December 18, 2007, 02:18:28 PM »
Hey, I whipped up a new list:
1. Awesome deal (4channel transmitter, receiver, 2 servos for just $110)
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBCP2**&P=0
2. Chassis with third deck (about 75$)
3. Futaba pan&tilt system from servocity.com ($20 plus ship+handling)
4. 12 rechargeable batteries from a local store (I'm estimating about 20-40 bucks)
So about $200-250. Considerable.  :D
« Last Edit: December 18, 2007, 09:58:33 PM by garriwilson »
Offline airman00
« Reply #11 on: December 18, 2007, 06:19:50 PM »
What about the camera. have you decided what you'll use?
also, the chassis is a rip off   - make your own out of plexiglass for a 1/4 of the price
Offline ed1380
« Reply #12 on: December 18, 2007, 07:39:50 PM »
+1 on price of the body
Offline airman00
« Reply #13 on: December 18, 2007, 07:49:16 PM »
What does that mean?
« Reply #14 on: December 18, 2007, 09:17:18 PM »
Yea, I second that.
thanks I forgot to put that
here: http://www.raidentech.com/miwicocaspyc.html
Two problems: what the heck is plexiglass and I don't really have any tools. (It's so pathetic I don't even have a power drill.  :'(
And even with the servos it's a ripoff?
I'll find out what plexiglass is on google.
« Last Edit: December 18, 2007, 09:21:40 PM by garriwilson »
« Reply #15 on: December 18, 2007, 09:55:36 PM »
I heard that tracks are hard to tension and get perfect. Should I just use wheels if I decide to make my own chassis?
Also, If I do make it, I'm probably going to use HDPE from McMaster.com
Can HDPE be cut be a utility knife? I mean relatively easy. I know that chassis is kind of a ripoff. If I had the tools, I would so make it.
« Reply #16 on: December 18, 2007, 10:34:12 PM »
How do I know what kind of batteries or battery pack I need for the transmitter and receiver in this:
I am pretty sure I need a 4.8v battery pack for the receiver, but for the transmitter how do I know if you put in alkaline batteries or attach a battery pack?
« Reply #17 on: December 18, 2007, 10:40:59 PM »
I want to get this battery (FUTABA): (http://www.servocity.com/html/4_8v_600mah_nicad_battery.html) the FUTABA one because my receiver is Futaba. But then the only NiCd charger says Hitec!!! Are they compatible.
Here is the charger: http://www.servocity.com/html/cg-25_charger.html
Offline airman00
« Reply #18 on: December 18, 2007, 10:47:45 PM »
I prefer to use plexiglass ( basically plastic glass , think hockey rink walls ) because it looks cool, but HDPE is much easier to work with.
I cut HDPE with a jigsaw
I actually bought this hobby tool - its a jigsaw , chisel, and sander all in one. It works well too ,@ only 50 bucks
http://www.sciplus.com/singleItem.cfm/terms/7948
Also just use wheels instead of tracks. And put a caster in front or back.
Looking at the picture of the charger , i cannot tell its ratings. It probably is compatible, but too make sure find a battery that IS MEANT to be compatible with that charger. Then we'll be able to figure it out. ;)
« Reply #19 on: December 19, 2007, 11:53:47 AM »
I want to get a battery pack over a battery holder because a battery pack has the connector thingy on the end and I don't know how to attach a battery holder to the receiver pins.
I might get that 3in1 tool but I'll ask my dad, he probably has a ton of tools at work maybe he could bring some. ?
I'm kind of a beginner and since HDPE is easy to work with I'll just stick with it. I might use plexiglass for future projects though. (This is my second project after the $50 robot).
So now I need to work on the design of my "robot." Also I heard that it is better to put the caster in the back. Is that true?
And airman00 thanks for telling me the chassis was a ripoff. I could use my already modified HS-311's from the $50 robot. So I'll only need to buy some tools and HDPE.
P.S. I've almost never worked with power tools, only power drill.
Offline airman00
« Reply #20 on: December 19, 2007, 12:46:01 PM »
why don't you just get a regular AA holder and buy a rechargeable AA charger and 4 rechargeable AA batteries???
What do you mean by put the caster in back? Back relative to what?
I think you're saying that you should have the motorized wheels in front , since pulling is better than pushing, and then the caster would be in back. Yea, then you should have the caster in front.
I would suggest you download Google Sketchup and make a 3D model of it, to scale. The model should be exactly like you want it , even with the drill holes.
Get the 3in1 tool, and you'll be working with HDPE with ease. What you need to work with HDPE is a drill, some  type of saw (handsaw, jigsaw is good) , sander( optional, but makes it smooth.
« Reply #21 on: December 19, 2007, 01:01:24 PM »
Because the regular AA holder doesn't have the molex pins that you plug into your receiver. It has a black and a red wire with the metal just sticking out.
you mean in the back?
I mean in the back like if there are 3 wheels, the ones with the servos are in front when it's going forward.
Yea I decided to get the 3in1 tool because I'm saving money on the chassis.
Thanks for the tool link airman00.
Offline airman00
« Reply #22 on: December 19, 2007, 01:03:08 PM »
Oops , yeah i meant in the back. With the servos in front , thats the best.
Also, why don't you just get a molex pin connector and crimp it onto the wires of the battery
« Reply #23 on: December 19, 2007, 01:20:38 PM »
Don't have a crimp tool-  :-[ .
I might get one in the future, but for now it's not necessary.
And there are only two wires
« Last Edit: December 19, 2007, 01:39:57 PM by garriwilson »
Offline airman00
« Reply #24 on: December 19, 2007, 02:24:52 PM »
Well yeah, power and ground. Some batteries have 3 wires, but thats just two wires form power and one from ground( unless its 2 batteries in one ) meaning theres total of lets say 6 batteries. The 3rd battery has a power wire coming from it ( which si 3V lets say) and the 6th battery has a wire which is 6 V. And they obviously share a common ground
« Reply #25 on: December 19, 2007, 02:44:26 PM »
Ok, I still don't have a crimp tool.
So, it doesn't matter if you only have two wires in a three pin molex connector and you connect it to the battery pins which has 3 pins sticking out?
Offline airman00
« Reply #26 on: December 19, 2007, 02:54:56 PM »
it does matter , what i was saying is to find out what each pin needs
lets say pin 1 and pin 2 are for power and pin 3 is ground. SO from the positive wire from teh battery you would solder on a second wire. All you are doing is giving the components what they need
« Reply #27 on: December 19, 2007, 03:02:55 PM »
OH Sorry, now I understand it perfectly. My bad.  :-[
I'll try to find some information about the receiver.
« Reply #28 on: December 19, 2007, 04:55:50 PM »
http://www.societyofrobots.com/electronics_wire_connector.shtml
It strongly depends on what your robot needs to do. There is a good post about it hidden somewhere in the forum if you do a search on casters.
Offline airman00
« Reply #29 on: December 19, 2007, 05:16:26 PM »
Yea, i asked that question awhile back
anyway here is that post http://www.societyofrobots.com/robotforum/index.php?topic=2224.0
Last post December 02, 2006, 04:06:46 PM
by robotramble_uhs
Last post September 03, 2007, 03:18:31 PM
by iliketobuildthings
Last post August 26, 2007, 05:40:58 PM
by dunk
Last post September 29, 2008, 12:32:45 AM
by Ant
