Author Topic: Gear reduction for belt  (Read 3354 times)
Offline kennykckTopic starter
« on: December 16, 2007, 10:54:36 PM »
If I'm using belt and pulley, does the gear reduction formula apply in this case too?
Note: one pulley is 5cm diameter (connected to the motor)
         The other is 10 cm diameter (connected to the application)
Offline Steve Joblin
Re: Gear reduction for belt
« Reply #1 on: December 17, 2007, 06:44:01 AM »
Make sure you measure the diameter of where the belt rides, not the outside diameter of the pully that includes the flange.
Offline Rebelgium
« Reply #2 on: December 17, 2007, 07:18:32 AM »
offcourse it does, only the direction will be different.
orgcrime.net
« Reply #3 on: December 19, 2007, 05:46:55 PM »
What type of belt (v-belt, timing belt, etc)?
Are there high dynamic loads?
I ask because unlike gears, you may need to account for slip.
kennykck, I noticed a lot of gear related questions from you. Building something interesting? :P
« Reply #4 on: December 20, 2007, 02:54:46 AM »
I'm using timing belt. High dynamic load? not sure bout that. So account the slip with how many percent?
So... I gets ur attention. ;D I'm doing this stuff
http://www.societyofrobots.com/robotforum/index.php?topic=2452.0
Lost most of my social life and gaming to it  :'(
« Reply #5 on: December 20, 2007, 06:05:55 AM »
Timing belts won't have slip, so don't worry about that.
However belts stretch, such as if you have a high load, or high dynamic load (high acceleration).
If you are building a robot arm with this, it will reduce the positional accuracy a bit.
