Author Topic: #4 screw  (Read 2884 times)
Offline airman00Topic starter
#4 screw
« on: December 17, 2007, 02:49:31 PM »
I need to make a hole on a CAD
What size diameter does a #4 machine screw go through?   Would 3/8" be good?
P.S. I cannot test it out tonight and so I need an answer today
Offline JonHylands
Re: #4 screw
« Reply #1 on: December 17, 2007, 03:06:40 PM »
A #4-40 machine screw goes through a 1/8" hole without touching the sides. 7/64 makes a much tighter fit, but hard to slide in and out. I usually drill my #4-40 clearance holes to 1/8".
If you want to drill a hole to tap for #4-40, you need to drill a hole using a #43 drill bit, which is roughly 0.089".
- Jon
Offline SomeSaba
Re: #4 screw
« Reply #2 on: December 17, 2007, 04:23:50 PM »
does anyone have a site that has a chart for all these?
They come in handy.. and i can never find them online
Offline JonHylands
Re: #4 screw
« Reply #3 on: December 17, 2007, 05:03:57 PM »
Re: #4 screw
« Reply #4 on: December 17, 2007, 06:36:29 PM »
Thanks guys,
 i got this equation to convert # into inches
Diameter = ( # x .013") + .06"
So a #4 screw would be .58" in diameter
Offline JonHylands
Re: #4 screw
« Reply #5 on: December 17, 2007, 06:58:30 PM »
Your equation is probably correct, but your math is way off.
(4 * 0.013") + 0.06" = 0.112"
- Jon
Re: #4 screw
« Reply #6 on: December 17, 2007, 08:02:52 PM »
- Jon
lol  , i realized that !  ;D  I was about to go back and correct the post, since I realized a .58" diameter screw is pretty thick, way too think for a #4/
anyway I used a 5/32" bit
Offline JonHylands
Re: #4 screw
« Reply #7 on: December 17, 2007, 08:32:05 PM »
5/32" will be way too big - your screw will wobble like crazy.
5/32" = 0.156"
I typically use 1/8", which is 0.125"...
- Jon
Re: #4 screw
« Reply #8 on: December 17, 2007, 08:36:00 PM »
thanks jon    ;D
1/8 it is !   ;)
i think i'm going to go to sleep now, i had no sleep in the past 24 hours
Last post December 14, 2008, 03:06:19 PM
Last post August 24, 2009, 05:55:23 PM
by Stephanie
Last post October 31, 2009, 03:19:51 AM
by robortwillys
Last post November 02, 2009, 02:43:09 AM
by Joker94
