Author Topic: helical gear  (Read 2596 times)
Offline kennykckTopic starter
helical gear
« on: December 18, 2007, 03:00:16 AM »
Sorry i have a noob question.
If i use 2 similar helix gear with 45 degree helix angle, connected together to form a change of the direction of rotation(much like bevel gear), is the torque & speed still the same?
Since i need to change the direction of my rotation, is using helical better option than bevel and worm gear?
Offline ed1380
Re: helical gear
« Reply #1 on: December 18, 2007, 07:21:57 AM »
yeah, you'll just be abel to transmit more torque (cars use them)
worm drive has a very high gear ratio reduction and is sometimes a one way deal. (worm can turn bevel, but not ther other way around)
Re: helical gear
« Reply #2 on: December 19, 2007, 12:36:09 AM »
anyone knows how to draw helical gear in Pro-E? I cant seems to draw the helix angle line in which my 2d profile gear tooth extrude along it.
Re: helical gear
« Reply #3 on: December 19, 2007, 05:43:33 PM »
yes . . . unless you account for efficiency ;D
