we all specialized in certain Fields. dunk with his internet control, airman00 with his butler bot voice recognition. but we are all saying we need one leader and i think that is true try admin for example if he was the leader he would see over the entire project. then we should have group leaders (programming, contruction)
Also we will need a open source programming area as well. Where functions for each module on a pic and avr are already made and you just download the code to go with each one and tie them together with your own code. It has potential but needs to be managed and a good system developed to manage the files and projects.
does anyone think we need a 3.3v supply? personally i think 5v is a better choice and people can regulate down to 3.3v if they need on a particular board.
licencing. who owns this? how do we stop someone else from patenting out work? i think we need a template Open Source type licence that anyone can copy into their project.
everyone alright with Eagle for board schematics?
i personally am with the idea of a subforum for the SOR project. it'll be alot easier to find threads about it, than having to look in every section for the SOR PROJECT heading.
Ok just to add a little organization to the coming projects I created a list of potential modules. This will be added to and modified over time to include who is working on what module so that people don't do more then one without combining their work.http://docs.google.com/Doc?docid=ddgqp9wc_0gpbcwmgm&hl=en
I have a suggestion for the board sizes and stacking possibility. If say we have a stack of 76x76 boards and want to stack a 38x38 or even several on top of the 76x76 board the mounting holes wouldn't fit the 38x38. If we as a standard put four holes in the middle of all the 76x76 boards, it would be possible to stack four 38x38 boards on one 76x76. Then we'll do the respectively needed with 76x38 boards.
The smaller boards may use only 2 holes in opposite corners.
I should probably comment on the motor driver . . .#2 for Right-Motor doesn't seem to have anything connecting to it.
Also, the trace width going to the motors is waaaaay too thin. There is lots of room for more red tracing, fill it up!
The trace separation distance for the lower blue plane, on some traces, looks really small . . .
For the programmer connector, put a big white triangle where pin 1 should be. This way a person won't connect it in reverse.
For the big 1000uF cap, it looks a bit small. Make sure the cap is rated for at least 24V.
Lastly, put it into 3D, I'm curious how it will look!
I enlarged it to 32 mils, but I have checked the trace width calculator and it says 12 mils for 1 amp at 1 oz/ft^2 copper thickness.
Oh, by the way, I didn't check prices for the parts. But the most expensive is the PCB. If done in quantities, it would worth to build it as a module. I am not a fan of making my own boards. I did that, had good results, but I want my boards to have solder mask and silk screen and most important, metalised holes.
I suggest there should also be a motor driver using the L298, this is a dual H bridge that can supply 2A continuously.
After Ro-Bot-X posts a 3D image of it plus dimensions, airman00 can you design up a google sketchup of it (since you have started the SoR Sketchup Library)?
The I 2 C-bus specificationTrasmissione Dati-I2CWiring pattern of the bus linesIn general, the wiring must be so chosen that crosstalk and interferenceto/from the bus lines is minimized. The bus lines are most susceptible tocrosstalk and interference at the HIGH level because of the relatively highimpedance of the pull-up devices.If the length of the bus lines on a PCB or ribbon cable exceeds 10 cm andincludes the VDD and VSS lines, the wiring pattern must be:SDAVDDVSSSCLIf only the VSS line is included, the wiring pattern must be:SDAVSSSCLThese wiring patterns also result in identical capacitive loads for the SDA andSCL lines. The VSS and VDD lines can be omitted if a PCB with a VSSand/or VDD layer is used.
Started by Fredrik Andersson Misc
Started by Crooksie Misc
Started by tonyg Misc
Started by Trumpkin « 1 2 3 4 » Misc
