Don't ad-block us - support your favorite websites. We have safe, unobstrusive, robotics related ads that you actually want to see - see here for more.
check the continuity between the ground pin and the power source.
I barely used this scope . . . something broken? Because I can't get a reliable voltage if the scaling is going to do that . . . Should I call up Tektronix?
how does that happen if not a single wire is connected to USB ground?!?
Are those scaling changes happening when your probe is grounded?
Internally the USB is tied to ground, that same ground is used for the scope which is connected to the meter.
The results are the same whether the leads are floating or directly connected to each other.
Moral of the story: don't use an oscope on mains power when measuring other stuff on mains power without being very careful of ground loops . . .
The ground should be tied to the USB ground not the meters ground.
Another way to get around this is to set the scope to GND coupling (instead of AC or DC) than move the horizontal line to zero followed by putting the scope back to AC or DC coupling
Started by Admin Electronics
Started by Ro-Bot-X Electronics
Started by Commanderbob Software
Started by kl22 Electronics
