2
Author Topic: Finally got my microcontroller working  (Read 3134 times)
Offline TrumpkinTopic starter
« on: January 10, 2008, 09:34:04 AM »
I'm sooooooooooo happy  ;D ;D ;D I finally got my $50 robot microcontroller working!!!! It took like 3 months just to get it working (not including the actual soldering of the circuit). It was all just because of a bridge in the programmer header. The only problemn is i ran the modify servo program and the servos are moving in opposite directions is it just the programming?
Robots are awesome!
Offline paulstreats
Re: Finally got my microcontroller working
« Reply #1 on: January 10, 2008, 09:40:01 AM »
They are supposed to.
Once they are mounted onto your bot they need to spin opposite to work correctly, youll realise when its all built
« Reply #2 on: January 10, 2008, 09:43:54 AM »
they are actually on my bot one is spinning forward the other backward.
Robots are awesome!
« Reply #3 on: January 10, 2008, 10:25:41 AM »
Are you giving the servos the correct pulse at the correct oscillator setting?
« Reply #4 on: January 10, 2008, 01:52:41 PM »
It was just the potentiometer shaft when I modifyed it for my RC system it wasn't the same as the microcontroller.
Robots are awesome!
Offline ed1380
« Reply #5 on: January 10, 2008, 02:49:38 PM »
maybe find out which servo it is code wise and change teh code around for it to work
« Reply #6 on: January 11, 2008, 08:35:20 AM »
I re-modified my servos I think it will work fine now
Robots are awesome!
« Reply #7 on: January 11, 2008, 09:10:06 AM »
Can somemone please post a sample program for the atmega 8 for just moving the servos? thx
Robots are awesome!
Offline ed1380
« Reply #8 on: January 11, 2008, 06:06:08 PM »
google servo exersisor. it should also be in the avrlib
« Reply #9 on: January 12, 2008, 09:36:03 AM »
I checked google coudn't find anything  :(
Robots are awesome!
« Reply #10 on: January 12, 2008, 11:16:55 PM »
if you look at my code for a bit, you will see a line calling the servos.
just run that line in the main section and comment out the other stuff.
