Author Topic: main gear-modify servo is this what we should cut out  (Read 3962 times)
Offline rox2007Topic starter
« on: January 14, 2008, 04:35:26 PM »
attached is the picture of underneath the main gear. i just want to know if the part circled red is what we should take out
Offline ed1380
Re: main gear-modify servo is this what we should cut out
« Reply #1 on: January 14, 2008, 04:49:35 PM »
you cant really take it out. i think.
if you cant then cut off the part of the pot that's supposed to go in that hole
« Reply #2 on: January 14, 2008, 05:06:57 PM »
if i have a drill cant i drill it out. make it rounder so that the large gear can rotate freely.
Offline ed1380
« Reply #3 on: January 14, 2008, 05:44:38 PM »
yes but it'll weaken the gear. it's already plastic and weak
Offline bukowski
« Reply #4 on: January 14, 2008, 06:09:52 PM »
you should be able to pop it out with some needle nose.
I had trouble with metal geared servo's with a ball bearing, it did not want to come out, and you can just cut the pot head off, like ed said
« Reply #5 on: January 14, 2008, 07:05:11 PM »
but if i made a mistake with the position and i want to adjust the position. am done for
Offline ed1380
« Reply #6 on: January 14, 2008, 08:47:08 PM »
if you're afraid of that then you could do this
http://www.instructables.com/id/ESCV6JIWXGEP2864QT/
just do what they say. when they say solder resistors to wires. do it. i tried to be cool and solder it directly to the pcb. well now IDK if teh servo works. it's all finicky
« Last Edit: January 14, 2008, 08:48:26 PM by ed1380 »
« Reply #7 on: January 15, 2008, 04:03:50 AM »
and this is why i dont use servos ;D
« Reply #8 on: January 15, 2008, 06:22:21 AM »
you've never used servos ever?
I always do this method, it always works!  Just make sure to use precision resistors with a tolerance of 1% or 2%, more than that it gets the servo confused slightly. I once used a 5% tolerance  resistor unknowingly and all that happened was i had to send a pulse of 153 to center it . a pulse of 103 to make it go to the leftmost position, a pulse of 203 to go to the rightmost position
Last post May 08, 2007, 02:27:24 PM
by hazzer123
Last post February 14, 2010, 08:28:11 PM
by BFerguson
Last post November 27, 2008, 02:30:42 PM
by Trumpkin
Last post January 27, 2009, 12:35:55 AM
