Author Topic: autonomous path follower and obstacle avoider  (Read 6792 times)
Offline ruffntuff007Topic starter
« on: January 15, 2008, 08:19:13 AM »
hello friends,
i am making a autonomous path follower and obstacle avoider, i want to use two servo/dc motors for two back weels and want to just attach a caster wheel for front wheet. so having a bot with three wheel , is any problem ?? what type of body should i build ????? ??? ???
Re: autonomous path follower and obstacle avoider
« Reply #1 on: January 15, 2008, 08:34:38 AM »
OK first
what do you mean by path follower? what is the path?
three wheel bot is no problem.
I would recommend using HDPE for the material, buy it from McMaster
also what microcontroller will you be using? and what is your budget
« Reply #2 on: January 15, 2008, 08:36:17 AM »
i have 4 friends to contribute. i already have bought a pic development board. going to programme it soon. where can i find hdpe ?
« Reply #3 on: January 15, 2008, 08:37:06 AM »
hello friends,
iam making a path follower and obstacle avoidance system.i am new to robotics, i want to use two  dc motors for two rear wheels and a caster wheel in the front.So my bot is having two motors and a caster wheel,total three wheels. Is my idea good enough to proceed ???
Don't double post
an any one tell me how to connect wheels to a motor ???
a regular motor or a servo . And also which exact motor and which exact servo
« Reply #4 on: January 15, 2008, 08:38:35 AM »
as I said before McMaster.com
Also I would first build the robot and then program it.  :P
Also, what is the path that it is following???
« Reply #5 on: January 15, 2008, 08:43:39 AM »
the path is  like B shape
« Reply #6 on: January 15, 2008, 08:46:39 AM »
its a servo hs-35 ,torgue 4 kg . now can u please tell me how to connect wheel to that motor ?? wheel  would be of  radius 2.5  cms.
« Reply #7 on: January 15, 2008, 08:47:06 AM »
a black electrical tape line?
lol
what is the path? out of what material , what color , what terrain    NOT what shape
« Reply #8 on: January 15, 2008, 08:48:11 AM »
here is a link on how to connect a wheel to a servo
lol, search google  :D
http://www.kronosrobotics.com/an118/GAN118.shtml
Offline Rebelgium
« Reply #9 on: January 15, 2008, 08:49:47 AM »
Do some research before you ask questions like if three wheeled robots are ok.
The forum is FILLED with info on three wheeled robots...
orgcrime.net
« Reply #10 on: January 15, 2008, 08:52:16 AM »
the path is a track of 60cm wide . its a flat surface,wood made
« Reply #11 on: January 15, 2008, 08:53:01 AM »
thanku :)
« Reply #12 on: January 15, 2008, 08:56:19 AM »
what color?
« Reply #13 on: January 15, 2008, 09:07:28 AM »
black colour track 60 cm wide aooden surface absolutely flat . do u have any pics of three wheeled bot ?
« Reply #14 on: January 15, 2008, 09:12:11 AM »
search GOOGLE!!!!
here is a robot that admin made :
I am working on a robot with two wheels and two casters, basically just for balance and to make room for my line sensors
Do you know how to track a line already?
« Reply #15 on: January 15, 2008, 09:18:00 AM »
actually  one of my friend is dealing with the programming part. i have taken the job to design chasis and essembling. do u have any other pic with a more of front look ???
« Reply #16 on: January 15, 2008, 10:03:20 AM »
just search google for it , i am not going to
how will you be doing the sensors part?
Offline bukowski
« Reply #17 on: January 15, 2008, 10:27:57 AM »
If you want something cheaper than an omniwheel, you could also go with a ball caster.
« Reply #18 on: January 15, 2008, 02:47:23 PM »
yea i built the $40 robot and put a ball caster on front works well...
Offline tjpark1111
« Reply #19 on: January 15, 2008, 03:48:01 PM »
can i buy HDPE from home depot?
Offline cooldog
« Reply #20 on: January 16, 2008, 11:19:13 AM »
A CHEAP SOURCE OF HDPE IS IN OLD CUTTING BORDS
sorry about the caps
-admin
favorite web sites
http://www.instructables.com/
« Reply #21 on: January 16, 2008, 02:51:54 PM »
old cutting, do you mean for use in like kitchens? because i have a lot of plastic cutting boards at home...
~smash
Offline cooldog
« Reply #22 on: January 16, 2008, 03:16:44 PM »
ya :D
-admin
favorite web sites
« Reply #23 on: January 16, 2008, 03:46:56 PM »
saweet! ill try and sneek one sometime :D
Last post December 11, 2007, 03:08:01 PM
by JonHylands
Last post June 05, 2010, 11:53:08 PM
by ishka
Last post June 12, 2011, 06:20:28 AM
by WaterPig Master
Last post July 20, 2011, 08:47:36 AM
by Adityav95
