Author Topic: Can someone tell me EXACTLY how to program the Atmega 8  (Read 6849 times)
Offline TrumpkinTopic starter
« on: January 16, 2008, 10:00:37 AM »
Yes I'm that stupid I can't figure out how to make the stupid servo turn. The code always compiles wrong. can someone post step by step instructions and code on how to do this? thx
Robots are awesome!
Re: Can someone tell me EXACTLY how to program the Atmega 8
« Reply #1 on: January 16, 2008, 12:07:34 PM »
what kind of errors do you get?
does this help?
http://www.societyofrobots.com/robotforum/index.php?topic=2724.0
stupid check:
sometimes I forget to save my code before I compile
« Reply #2 on: January 16, 2008, 04:20:00 PM »
Oh i didn't know you had to save it before compiling i'll try that but I don't think that is the problem
Robots are awesome!
« Reply #3 on: January 17, 2008, 09:15:12 AM »
Nope not the problem. Admin, do I need SoR_utils.h for sucha simple program? please excuse my ignorance on this subject. :D My dad has been trying to do the programming but cant get it to work either the error is unexpected EOF there is two of those it says for both lines 1 and 2
Robots are awesome!
« Reply #4 on: January 17, 2008, 09:20:09 AM »
Can you explain better what you are trying to do? Also, can you copy/paste the exact error?
Are you using my $50 Robot code? Does that compile properly without modification?
Did you set up the makefile properly (as in the tutorial)?
http://www.societyofrobots.com/step_by_step_robot_step4.shtml
« Reply #5 on: January 17, 2008, 09:34:45 AM »
I did see that part in the tutorial never did it for some reson though ::). At first i was going to have a servo move but now im just going to turn on an led here is my code
//SoR Include
#include "SoR_Utils.h" //includes all the technical stuff
int main(void)
configure_ports(); // configure which ports are analog, digital, etc.
a2dInit(); // initialize analog to digital converter (ADC)
a2dSetPrescaler(ADC_PRESCALE_DIV32); // configure ADC scaling
a2dSetReference(ADC_REFERENCE_AVCC); // configure ADC reference voltage
LED_on(); //turn LED on
return 0;
 and here are my errors
 /usr/bin/sh: -c: line 1: unexpected EOF while looking for matching `''
/usr/bin/sh: -c: line 2: syntax error: unexpected end of file
I just modified the photovore code but obviously I didn't do it right
Robots are awesome!
« Reply #6 on: January 17, 2008, 09:54:28 AM »
Ok i did the makefile part and now I have this error
make: *** No rule to make target `Photovore_v1.elf', needed by `elf'.  Stop.
Robots are awesome!
« Reply #7 on: January 17, 2008, 10:13:56 AM »
Yea you can't skip steps or it won't work . . . ;)
I suspect your folders aren't named properly . . .
Start from scratch. Follow each step carefully, don't skip a step, and then compile it.
Then to modify it, just make small changes and then compile again. If it works, continue. If not, you know which change breaks it.
« Reply #8 on: January 21, 2008, 02:03:14 PM »
I followed the steps exactly and got the same error  >:( >:(
Robots are awesome!
Offline rgcustodio
« Reply #9 on: January 21, 2008, 02:41:46 PM »
Look at your Makefile. You might have inadvertently edited it or something. I'm assuming that your target is missing a dependency. Or maybe you renamed the .c files??
If your using the Photovore code made by Admin for the $50 Robot and you rename the files (specially Photovore_1.c) you will get this error. You will also get this error if you try to use the Makefile in another project.
« Reply #10 on: January 21, 2008, 03:29:40 PM »
me and my dad both already looked through the makefile. my dad says that there is something wrong with it I can't remember what he said was wrong with it  ::). I'll ask him later
Robots are awesome!
« Reply #11 on: January 23, 2008, 09:34:31 AM »
here is the makefile code I would really appreciate it if someone could look through it for me
# Hey Emacs, this is a -*- makefile -*-
# WinAVR Sample makefile written by Eric B. Weddington, Jörg Wunsch, et al.
# Released to the Public Domain
# Please read the make user manual!
# Additional material for this makefile was submitted by:
#  Tim Henigan
#  Peter Fleury
#  Reiner Patommel
#  Sander Pool
#  Frederik Rouleau
#  Markus Pfaff
# On command line:
# make all = Make software.
# make clean = Clean out built project files.
# make coff = Convert ELF to AVR COFF (for use with AVR Studio 3.x or VMLAB).
# make extcoff = Convert ELF to AVR Extended COFF (for use with AVR Studio
#                4.07 or greater).
# make program = Download the hex file to the device, using avrdude.  Please
#                customize the avrdude settings below first!
# make filename.s = Just compile filename.c into the assembler code only
# To rebuild project do "make clean" then "make all".
# MCU name
MCU = atmega8
# Processor frequency.
#     This will define a symbol, F_CPU, in all source code files equal to the
#     processor frequency. You can then use this symbol in your source code to
#     calculate timings. Do NOT tack on a 'UL' at the end, this will be done
#     automatically to create a 32-bit value in your source code.
#     Typical values are:
#         F_CPU =  1000000
#         F_CPU =  1843200
#         F_CPU =  2000000
#         F_CPU =  3686400
#         F_CPU =  4000000
#         F_CPU =  7372800
#         F_CPU =  8000000
#         F_CPU = 11059200
#         F_CPU = 14745600
#         F_CPU = 16000000
#         F_CPU = 18432000
#         F_CPU = 20000000
F_CPU = 3686400
# Output format. (can be srec, ihex, binary)
FORMAT = ihex
# Target file name (without extension).
TARGET = Photovore_v1
# List C source files here. (C dependencies are automatically generated.)
SRC = $(TARGET).c a2d.c
#SRC = $(TARGET).c timer.c uart.c buffer.c rprintf.c
# List Assembler source files here.
# Make them always end in a capital .S.  Files ending in a lowercase .s
# will not be considered source files but generated files (assembler
# output from the compiler), and will be deleted upon "make clean"!
# Even though the DOS/Win* filesystem matches both .s and .S the same,
# it will preserve the spelling of the filenames, and gcc itself does
# care about how the name is spelled on its command-line.
ASRC =
# Optimization level, can be [0, 1, 2, 3, s].
# 0 = turn off optimization. s = optimize for size.
# (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
OPT = 0
# Debugging format.
# Native formats for AVR-GCC's -g are stabs [default], or dwarf-2.
# AVR (extended) COFF requires stabs, plus an avr-objcopy run.
DEBUG = stabs
# List any extra directories to look for include files here.
#     Each directory must be seperated by a space.
EXTRAINCDIRS =
# Compiler flag to set the C Standard level.
# c89   - "ANSI" C
# gnu89 - c89 plus GCC extensions
# c99   - ISO C99 standard (not yet fully implemented)
# gnu99 - c99 plus GCC extensions
CSTANDARD = -std=gnu99
# Place -D or -U options here
CDEFS =
# Place -I options here
CINCS =
# Compiler flags.
#  -g*:          generate debugging information
#  -O*:          optimization level
#  -f...:        tuning, see GCC manual and avr-libc documentation
#  -Wall...:     warning level
#  -Wa,...:      tell GCC to pass this to the assembler.
#    -adhlns...: create assembler listing
CFLAGS = -g$(DEBUG)
CFLAGS += $(CDEFS) $(CINCS)
CFLAGS += -O$(OPT)
CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
CFLAGS += -Wall -Wstrict-prototypes
CFLAGS += -Wa,-adhlns=$(<:.c=.lst)
CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
CFLAGS += $(CSTANDARD)
# Assembler flags.
#  -ahlms:    create listing
#  -gstabs:   have the assembler create line number information; note that
#             for use in COFF files, additional information about filenames
#             and function names needs to be present in the assembler source
#             files -- see avr-libc docs [FIXME: not yet described there]
ASFLAGS = -Wa,-adhlns=$(<:.S=.lst),-gstabs
#Additional libraries.
# Minimalistic printf version
PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
# Floating point printf version (requires MATH_LIB = -lm below)
PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
PRINTF_LIB =
# Minimalistic scanf version
SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
# Floating point + %[ scanf version (requires MATH_LIB = -lm below)
SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
SCANF_LIB =
MATH_LIB = -lm
# External memory options
# 64 KB of external RAM, starting after internal RAM (ATmega128!),
# used for variables (.data/.bss) and heap (malloc()).
#EXTMEMOPTS = -Wl,-Tdata=0x801100,--defsym=__heap_end=0x80ffff
# only used for heap (malloc()).
#EXTMEMOPTS = -Wl,--defsym=__heap_start=0x801100,--defsym=__heap_end=0x80ffff
EXTMEMOPTS =
# Linker flags.
#  -Wl,...:     tell GCC to pass this to linker.
#    -Map:      create map file
#    --cref:    add cross reference to  map file
LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
LDFLAGS += $(EXTMEMOPTS)
LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
# Programming support using avrdude. Settings and variables.
# Programming hardware: alf avr910 avrisp bascom bsd
# dt006 pavr picoweb pony-stk200 sp12 stk200 stk500
# Type: avrdude -c ?
# to get a full listing.
AVRDUDE_PROGRAMMER = avrisp
# com1 = serial port. Use lpt1 to connect to parallel port.
AVRDUDE_PORT = com1    # programmer connected to serial device
AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
#AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
# Uncomment the following if you want avrdude's erase cycle counter.
# Note that this counter needs to be initialized first using -Yn,
# see avrdude manual.
#AVRDUDE_ERASE_COUNTER = -y
# Uncomment the following if you do /not/ wish a verification to be
# performed after programming the device.
#AVRDUDE_NO_VERIFY = -V
# Increase verbosity level.  Please use this when submitting bug
# reports about avrdude. See <http://savannah.nongnu.org/projects/avrdude>
# to submit bug reports.
#AVRDUDE_VERBOSE = -v -v
AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
# Define directories, if needed.
DIRAVR = c:/winavr
DIRAVRBIN = $(DIRAVR)/bin
DIRAVRUTILS = $(DIRAVR)/utils/bin
DIRINC = .
DIRLIB = $(DIRAVR)/avr/lib
# Define programs and commands.
SHELL = sh
CC = avr-gcc
OBJCOPY = avr-objcopy
OBJDUMP = avr-objdump
SIZE = avr-size
NM = avr-nm
AVRDUDE = avrdude
REMOVE = rm -f
COPY = cp
# Define Messages
# English
MSG_ERRORS_NONE = Errors: none
MSG_BEGIN = -------- begin --------
MSG_END = --------  end  --------
MSG_SIZE_BEFORE = Size before:
MSG_SIZE_AFTER = Size after:
MSG_COFF = Converting to AVR COFF:
MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
MSG_FLASH = Creating load file for Flash:
MSG_EEPROM = Creating load file for EEPROM:
MSG_EXTENDED_LISTING = Creating Extended Listing:
MSG_SYMBOL_TABLE = Creating Symbol Table:
MSG_LINKING = Linking:
MSG_COMPILING = Compiling:
MSG_ASSEMBLING = Assembling:
MSG_CLEANING = Cleaning project:
# Define all object files.
OBJ = $(SRC:.c=.o) $(ASRC:.S=.o)
# Define all listing files.
LST = $(ASRC:.S=.lst) $(SRC:.c=.lst)
# Compiler flags to generate dependency files.
GENDEPFLAGS = -Wp,-M,-MP,-MT,$(*F).o,-MF,.dep/$(@F).d
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
# Default target.
all: begin gccversion sizebefore build sizeafter finished end
build: elf hex eep lss sym
elf: $(TARGET).elf
hex: $(TARGET).hex
eep: $(TARGET).eep
lss: $(TARGET).lss
sym: $(TARGET).sym
# Eye candy.
# AVR Studio 3.x does not check make's exit code but relies on
# the following magic strings to be generated by the compile job.
begin:
@echo
@echo $(MSG_BEGIN)
finished:
@echo $(MSG_ERRORS_NONE)
end:
@echo $(MSG_END)
@echo
# Display size of file.
HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
ELFSIZE = $(SIZE) -A $(TARGET).elf
sizebefore:
@if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); echo; fi
sizeafter:
@if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); echo; fi
# Display compiler version information.
gccversion :
@$(CC) --version
# Program the device.
program: $(TARGET).hex $(TARGET).eep
$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
# Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
COFFCONVERT=$(OBJCOPY) --debugging \
--change-section-address .data-0x800000 \
--change-section-address .bss-0x800000 \
--change-section-address .noinit-0x800000 \
--change-section-address .eeprom-0x810000
coff: $(TARGET).elf
@echo
@echo $(MSG_COFF) $(TARGET).cof
$(COFFCONVERT) -O coff-avr $< $(TARGET).cof
extcoff: $(TARGET).elf
@echo
@echo $(MSG_EXTENDED_COFF) $(TARGET).cof
$(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
# Create final output files (.hex, .eep) from ELF output file.
%.hex: %.elf
@echo
@echo $(MSG_FLASH) $@
$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
%.eep: %.elf
@echo
@echo $(MSG_EEPROM) $@
-$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
--change-section-lma .eeprom=0 -O $(FORMAT) $< $@
# Create extended listing file from ELF output file.
%.lss: %.elf
@echo
@echo $(MSG_EXTENDED_LISTING) $@
$(OBJDUMP) -h -S $< > $@
# Create a symbol table from ELF output file.
%.sym: %.elf
@echo
@echo $(MSG_SYMBOL_TABLE) $@
$(NM) -n $< > $@
# Link: create ELF output file from object files.
.SECONDARY : $(TARGET).elf
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
@echo
@echo $(MSG_LINKING) $@
$(CC) $(ALL_CFLAGS) $(OBJ) --output $@ $(LDFLAGS)
# Compile: create object files from C source files.
%.o : %.c
@echo
@echo $(MSG_COMPILING) $<
$(CC) -c $(ALL_CFLAGS) $< -o $@
# Compile: create assembler files from C source files.
%.s : %.c
$(CC) -S $(ALL_CFLAGS) $< -o $@
# Assemble: create object files from assembler source files.
%.o : %.S
@echo
@echo $(MSG_ASSEMBLING) $<
$(CC) -c $(ALL_ASFLAGS) $< -o $@
# Target: clean project.
clean: begin clean_list finished end
clean_list :
@echo
@echo $(MSG_CLEANING)
$(REMOVE) $(TARGET).hex
$(REMOVE) $(TARGET).eep
$(REMOVE) $(TARGET).obj
$(REMOVE) $(TARGET).cof
$(REMOVE) $(TARGET).elf
$(REMOVE) $(TARGET).map
$(REMOVE) $(TARGET).a90
$(REMOVE) $(TARGET).sym
$(REMOVE) $(TARGET).lnk
$(REMOVE) $(TARGET).lss
$(REMOVE) $(OBJ)
$(REMOVE) $(LST)
$(REMOVE) $(SRC:.c=.s)
$(REMOVE) $(SRC:.c=.d)
$(REMOVE) .dep/*
# Include the dependency files.
-include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
# Listing of phony targets.
.PHONY : all begin finish end sizebefore sizeafter gccversion \
build elf hex eep lss sym coff extcoff \
clean clean_list program
and here is my problem once again
Robots are awesome!
Offline rgcustodio
« Reply #12 on: January 23, 2008, 10:26:19 AM »
your makefile is similar to the $50 Robot makefile. if you are using the source code from Admin everything should compile (i've tried it). i'm assuming you are compiling this on Windows using AVR Studio?
do you have a file named Photovore_v1.c?
what are the .c files in your project?
what other items did you tweak?
as a test, get the source code's ZIP file (http://www.societyofrobots.com/downloads/sbs_source_photovore_v1.zip) again, uncompress it and build it. if this fails to build, something is wrong with your development environment (AVR Studio, et al). if it builds properly, maybe you can transfer your modifications from the non-compiling environment to this new environment.
« Reply #13 on: January 23, 2008, 11:29:34 AM »
yes I am using Admins source code and compiling it on Windows with AVR studio. I have Photovore_v1.c under source files, SoR_Utils.h under header files, and makefile where it should be according to the instructions. I changed the LED_off(); to LED_on(); I think that's about it. I will try getting the source code again.
Robots are awesome!
Offline DomoArigato
« Reply #14 on: January 23, 2008, 10:46:04 PM »
Can you compile any C code in AVR studio.  I think I had similiar errors when I didn't set up WinAVR correcty.  I also get similiar errors when I accidentally named the project Photovorev_1.
« Last Edit: January 24, 2008, 12:03:34 AM by DomoArigato »
« Reply #15 on: January 24, 2008, 09:49:50 AM »
how do you rename a project?
Robots are awesome!
« Reply #16 on: January 24, 2008, 09:51:10 AM »
I just got this error I didn't compile it or anything. gcc plug-in: Failed getting project file status
Robots are awesome!
« Reply #17 on: January 24, 2008, 02:01:34 PM »
So . . . you installed everything exactly the same, no modifications, and its not working?
You either missed a step, or modified something to be different . . .
Are you sure there are no spaces in the file path?
For example, do not do 'C:\Documents and Settings\User\Desktop . . .'
Also, the project file name must be the same name as the initial file.
« Reply #18 on: January 25, 2008, 09:25:00 AM »
I finally got the program to work! I just did it all over again. Im soo happy.  ;D ;D
Robots are awesome!
« Reply #19 on: January 25, 2008, 09:46:09 AM »
Congratulations , also lets see some pics and video of your robot! ;)
« Reply #20 on: January 25, 2008, 09:53:30 AM »
Ok i should be getting my IR rangefinder and scanning servo today or tomorrow.  And then I will have to figure out how to program them (I will probably use admins code for IR upgrade) but now that I know how to it shouldn't be too hard. I still have to finish building the chassis too but I think most of the hardwork is done. My final goal is to do adaptive mapping. kinda working my up.  :P
Robots are awesome!
