Author Topic: Speech Recognition  (Read 2537 times)
Offline airman00Topic starter
Speech Recognition
« on: January 17, 2008, 01:18:57 PM »
I found this schematic for a speech recognition kit online which sells for 80 bucks
If I make a PCB using that schematic can I just etch it out myself ( is there any legal issue)
And would I end up saving money rather than buying it?
Offline ed1380
Re: Speech Recognition
« Reply #1 on: January 17, 2008, 03:08:02 PM »
what abour programming? do you have the source code or is everything hardware done?
« Reply #2 on: January 17, 2008, 05:09:35 PM »
I believe its just hardware , the actual interface circuit( not pictured)  to the speech recognition needs a PIC ,but source code is online
« Reply #3 on: January 20, 2008, 09:26:28 PM »
unless they patented it, nope, no problem.
and if you didn't sell it, they wouldn't even care if you copied it . . .
well . . . time is money . . . and the one you make might not be as reliable
you might also want to look up if that HM 2007 chip needs to be programmed or not . . .
Offline Bubbles
« Reply #4 on: January 23, 2008, 03:24:36 AM »
yeah. i can't see them caring if u copied it seeing as how they gave you the schematic !  ;D  !
Last post August 26, 2008, 06:15:41 AM
by airman00
Last post October 12, 2009, 01:07:35 AM
by radhoo
Last post May 05, 2010, 05:53:03 AM
by dunk
Last post May 26, 2010, 05:51:30 PM
by SeagullOne
