Author Topic: need help with pwm in atmega168  (Read 4954 times)
Offline rox2007Topic starter
« on: January 18, 2008, 09:33:18 PM »
please
Offline hazzer123
Re: need help with pwm in atmega168
« Reply #1 on: January 19, 2008, 09:13:34 AM »
please post more about your problem
www.icrobotics.co.uk
« Reply #2 on: January 19, 2008, 09:22:14 AM »
i have two servos that i would like to control with PWM because i cant seem to get it right anyother way.
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
« Reply #3 on: January 19, 2008, 09:37:27 AM »
You like to be secretive, don't you? We can't guess your setup, you have to explain more.
If you are using Arduino, there is a library that uses Timer1 to generate PWM servo pulses. http://www.arduino.cc/playground/ComponentLib/Servotimetimer1
If you are using $50 robot there is this tutorial: http://mil.ufl.edu/~achamber/servoPWMfaq.html
Offline rgcustodio
« Reply #4 on: January 19, 2008, 10:03:11 AM »
i guess rox2007 is referring to his problem posted here:
http://www.societyofrobots.com/robotforum/index.php?topic=2917.0
« Reply #5 on: January 19, 2008, 10:59:42 AM »
yep, would really appreciate any help
« Reply #6 on: January 19, 2008, 11:03:19 AM »
how would i modify it for a hacked servo
this tutorial is helpful. it actually leads to this
http://mil.ufl.edu/~achamber/servoPWMwCodeVision.html
but the codevision i have, which is the new one does not look like what was described in that tutorial
« Last Edit: January 19, 2008, 11:04:19 AM by rox2007 »
Offline Ro-Bot-X
  • Helpful? 25
« Reply #7 on: January 20, 2008, 01:41:29 AM »
A modified servo for continuous rotation is controlled exactly the same as a regular servo. If you send a pulse between 1 ms to 1.5 ms, the servo will rotate counterclockwise at a different speed, the 1.5 ms pulse makes the servo stop and a pulse between 1.5 ms and 2 ms will make the servo rotate clockwise at a different speed. It all depends on servo quality. Some servos just rotate at the maximum speed no matter what pulse you give.
« Reply #8 on: January 20, 2008, 09:46:40 AM »
sorry i didnt say this earlier, but it worked...:)
thanks alot for the link. to use it with an atmega 168 you need the file incompato.h, i found it on google.
Last post September 26, 2007, 11:19:12 PM
by tych0
Last post October 22, 2007, 10:48:07 PM
by claesson92
Last post December 19, 2007, 09:15:49 PM
by SomeSaba
Last post March 30, 2008, 03:19:31 PM
