Author Topic: 7.2 volt battery  (Read 2831 times)
Offline TrumpkinTopic starter
7.2 volt battery
« on: January 19, 2008, 11:34:24 AM »
I was wondering if the $50 robot microcontroller can run  on a 7.2 volt battery pack.
Robots are awesome!
Offline rgcustodio
Re: 7.2 volt battery
« Reply #1 on: January 19, 2008, 11:51:32 AM »
the robot should be able to handle a 7.2 battery pack:
http://www.societyofrobots.com/schematics_powerregulation.shtml
the part used, KA7805ETU-ND, can handle a max Vin (input voltage) of 35VDC according to the data sheet (Absolute Maximum Ratings on page 2):
http://www.fairchildsemi.com/ds/KA/KA7805E.pdf
« Reply #2 on: January 19, 2008, 02:18:18 PM »
thx!
Robots are awesome!
« Reply #3 on: January 25, 2008, 07:58:42 PM »
servos cannot handle 7.2V, but the microcontroller with the 5V regulator can.
Offline SkinnyDog
« Reply #4 on: January 27, 2008, 11:24:55 AM »
Hi guys
 Newbe here, i think i also went a bit over kill when i ordered my battery got a 7.2v 3000mah only realised the size when i got it, the connector plug?male pins is a lot bigger(thicker gauge wire) will have to down size it through the on/off switch.
This will work?
Electronics is foreign to me as i studied Mechanical Eng. im ok putting it all together if shown how but the calculations and terms are a bit of o struggle, i did manage to get my solar engine to work from my gunk bot book, it did take some time though.
Offline gamefreak
  • Robo-Enthusiast
« Reply #5 on: January 27, 2008, 11:30:35 AM »
the gauge is generally for the amount of current being drawn, more current lower gauge, thicker wire
lower gauge is thicker, dont ask me why. so as long as you dont have the full 3 amps, you should be fine but if your thinner wires start smoking/melting/exploding then you may have a problem :P
Offline frank26080115
« Reply #6 on: January 27, 2008, 11:50:52 AM »
Servos can, and my servos haven't failed yet
« Reply #7 on: January 27, 2008, 03:19:09 PM »
yea i usually use 9V or 6V motors and then a 7.2V pack. it usually works for me :)
~smash
Offline ed1380
« Reply #8 on: January 27, 2008, 04:06:59 PM »
remember motors dont have electronics inside and they're ok with overvoltage, but servos arent
« Reply #9 on: January 27, 2008, 07:52:49 PM »
yeah so basically i probably don't want to usea 7.2 volt battery with the $50 robot microcontroller. Just wondering cause I was planning on making a $50 robot microcontroller for some1 else and I had a 7.2 volt battery on hand. Couldn't I put a couple of diodes between the battery and microcontroller to reduce the voltage to 6v?
Robots are awesome!
Offline ed1380
« Reply #10 on: January 27, 2008, 07:58:38 PM »
you mean resistors, right? cause diodes wont help.
resistors would turn that extra enery into heat. same thing the regular 5v regulator does. get a switching regulator
« Reply #11 on: January 27, 2008, 08:00:11 PM »
I think it will work . . . check the diode datasheet to make sure it can handle your required voltage/current/power requirements.
« Reply #12 on: January 27, 2008, 08:01:50 PM »
Ok, i'll try that, thx!
Robots are awesome!
« Reply #13 on: January 27, 2008, 08:19:35 PM »
true , but diodes have a voltage drop of about 1 V
Last post July 06, 2008, 10:49:15 AM
by twintriode
Last post September 19, 2008, 10:34:58 PM
Last post October 07, 2008, 06:18:31 AM
Last post December 17, 2008, 06:35:51 AM
by izua
