Author Topic: Microcontroller board power requirements  (Read 2560 times)
Offline BubblesTopic starter
« on: January 21, 2008, 09:31:22 PM »
I have this board here:
http://www.futurlec.com.au/ATMEGA8535_Controller_Technical.jsp
and on that page it says that it needs 5v to run, i was wondering 2 things.
1. can i use something like 6v to run it instead or would that be bad?
2. will this supply the power to my servos/sensors or do hey need to be wired to their own battery packs?
Re: Microcontroller board power requirements
« Reply #1 on: January 21, 2008, 09:38:43 PM »
OK so the page calls for a 5V power supply. So you would need a 5V regulator. Now to power that regulator you need a voltage of above 7 volts.
Servos should not be powered from the regulator but from a regular , unregulated 6V source , but sensors can be powered from either regulated or unregulated power , doesn't matter
My guess is the board will run at 6V , since most microcontrollers are meant to run from between 4.8 and 6 volts, I run my PIC micros @ 6V all the time.
If you are scared then take a 6V battery and attach a diode to it (which usually drops the voltage by 1 volt as a side effect )  and then connect the diode end to the microcontroller .
Any questions?
Cheers,
Eric
Last post January 20, 2008, 10:56:29 PM
by rox2007
Last post November 12, 2008, 12:49:53 AM
by pomprocker
Last post October 06, 2008, 10:53:31 AM
by ArcMan
Last post September 19, 2010, 02:24:21 PM
by garrettg84
