Author Topic: URGENT!!! anyone out der who made a sandwich robot, a line follower?  (Read 22852 times)
Offline roseTopic starter
HELLO
I am on my way in making my first robot and so i want something that is not that complicated like a robot w/out microcontrollers. I found the info on the net robotroom.com of david cook. There is no exact info I can use, like no specific parts and step by step instructions. Another one is there is no circuit schematic diagram. And also, I need this for our requirement before graduation in our physics class. It is due on February 07, 2008.
Any help will be much appreciated...
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Re: URGENT!!! anyone out der who made a sandwich robot, a line follower?
« Reply #1 on: January 23, 2008, 10:17:52 AM »
It's all in his first book, Robot Building
for Beginners.
Offline arsenius
« Reply #2 on: January 23, 2008, 02:03:48 PM »
I just bought that as an ebook (pdf) from apress.com.
Check it out, it's worth it for $15 (cheaper than amazon).
« Reply #3 on: January 23, 2008, 06:26:03 PM »
tnx 4 ur response!!!
can u pls send d schematic circuit, i don't have money to buy the book. Actually i've been searching 4 a week now, n its keeping me crazy. So please help me build my first robot.
Offline Bubbles
« Reply #4 on: January 23, 2008, 09:23:11 PM »
if u want to make a robot without a microcontroller why not check out the $40 dollar robot tutorial on this site (i don't think it needs an mcu) also, if u r having difficulty coming up with $15 dollars for an e-book you are probably going to find it hard to come up with enough money for a robot
« Reply #5 on: January 24, 2008, 12:25:43 AM »
yea normally you will spend about $100 for your first
~smash
« Reply #6 on: January 24, 2008, 02:39:14 AM »
I can't afford a $15 book because I have many requirements 2 submit b4 graduation and my money isn't dat many 2 include d book.
According 2 my research of the sandwich robot, dis r d parts:
2 1k Resistors
4 150ohm Resistors
2 20k Trimpots
3 1N5818 Diodes
1 LM393 Op-Amp
2 2N2907 Transistors
8 High Intensity LEDs
1 Power Switch
1 330µF Electrolytic Capacitor
1 0.1µF Capacitor
4 CDS Cells
1 SWT7 Dark/Light sensor config switch
4 #2-56 x 3/4" Bolts and Nuts for mounting
1 8-Pin Dip IC Carrier
1 SandPCB - Sandwich PCB
2 Gear Motors
2 Gear Motor Plastic Wheels
If u'll buy a kit on d net, it will cost u $75. But in hir, in the philippines, d parts r only $20. The problem is I do not know how to do it.
So pls, i need ur help about dis...
« Reply #7 on: January 24, 2008, 03:31:11 AM »
i still sugest the $40 robot.
« Reply #8 on: January 24, 2008, 07:21:00 AM »
listen rose
the sandwich robot is just a line follower robot using comparators , search for schematics for those type of lien followers
« Reply #9 on: January 24, 2008, 07:29:56 AM »
This is basically the same as the sanwich robot
http://www.seas.upenn.edu/~ese111/robot/Robot.html
also the 40 dollar robot is good and very well documented
« Reply #10 on: January 24, 2008, 09:15:46 AM »
I would still be doing sandwich robot, i just need to study some of the information I've gathered n given by some of you out there...
But I have another problem, the circuit board. How can I make a point to point wiring? Because I'm pretty sure I can etched at dis tum, I don't have any background about it.
Again, I'm asking 4 Ur help about other things I needed to know 2 build dis robot before d submission on Feb 6. Please help! If there is someone who can give me ALL the names of the parts needed and d full step by step intructions, I WILL APPRECIATE IT VERY MUCH! I AWE YOU MY GRADUATION! THANKS!!!
Offline Trumpkin
« Reply #11 on: January 24, 2008, 09:37:43 AM »
I say go with the $40 robot as I don't think anyone on this site has done sandwich bot. I think it is highly unlikely that u will be able to get sandwich bot done before february 7th because it is not documented well.
Robots are awesome!
« Reply #12 on: January 24, 2008, 04:55:49 PM »
unless you jsut buy the e book   ;)
it has full isntructions
OR build the fricken 40 dollar robot!  :D
« Reply #13 on: January 24, 2008, 05:42:06 PM »
yay! up with the $40 robot!! power to the poor! ;D
~smash
« Reply #14 on: January 24, 2008, 05:52:52 PM »
 smash can i see your version of the 40 dolalr robot u built
Offline Bubbles
« Reply #15 on: January 24, 2008, 06:13:46 PM »
yeah. unless you HAVE to do the sandwich robot for some reason or another i would go $40 robot as it is well documented and i am sure you can do it before the due date.
exactly  :P
Offline Trumpkin
« Reply #16 on: January 24, 2008, 07:36:54 PM »
here is the link to the $40 robot incase you couldn't find it! http://www.societyofrobots.com/member_tutorials/node/59
Robots are awesome!
« Reply #17 on: January 24, 2008, 07:56:52 PM »
yea i've looked around the net and cant find any good instructions that are free for the sandwhich bot..
~smash
« Reply #18 on: January 25, 2008, 03:00:39 AM »
tnx 4 d link... I don't understand wat everyone is saying because i didn't see dis yet. But now, since I've found dis, i think its easier n cheaper. Thanks a lot for ur help. It is well documented.
Can I still asked u about certain things about dis $40 robot, wen I don't understand something???
THANK YOU VERY MUCH!!! U REALLY HELP ME.
Offline ed1380
« Reply #19 on: January 25, 2008, 07:05:56 AM »
np. that's what we're here for.
if you have some time you can read up a bit. and it's free;
http://rapidshare.com/files/84939931/Wiley_-_Electronics_For_Dummies_-_2005_-__By_Laxxuss_.pdf
Offline Trumpkin
« Reply #20 on: January 26, 2008, 06:20:05 PM »
Yes, of course, please do.
Robots are awesome!
« Reply #21 on: January 26, 2008, 11:36:16 PM »
can I use a motor from a tamiya lets go? I can't find 100 rpm dc motor...
can d $40 make a sharp turns? i want to make the traking field to be challenging 4 d robot lyk a spiral maybe...
« Reply #22 on: January 26, 2008, 11:58:30 PM »
yes it can. and check the reply i sent you.
Offline lego-robot
« Reply #23 on: January 27, 2008, 12:56:28 AM »
yes i would say it would be able to make sharpish turns but it might be a bit slow. as for a spiral it should get around that quite easily but just dont put the lines to close to each other because it can sometimes jump them.
« Reply #24 on: January 27, 2008, 02:14:50 AM »
how about the photoresistor?
wat else can i substitute if i can't find a cds photoresistor?
« Reply #25 on: January 27, 2008, 02:49:42 AM »
umm...photoresistors are one of the most available parts. you should be able to get them.
~smash
« Reply #26 on: January 27, 2008, 03:52:26 AM »
ok, i think i can find dem. I will buy all d parts 2m.
May I ask? I have wheels hir but they r not 7.5diameter, I think dey r just 4 diameter. Can I use dem for my $40 robot?
Tnx 4 ol those who helped and still helping!
« Reply #27 on: January 27, 2008, 04:30:19 AM »
Another 1 is, how can i add music to it? Its d 1st robotics exibition in school, so it should be cool and amazing, ryt? So help me pls. Step by step instruction please!!!
« Reply #28 on: January 27, 2008, 04:39:31 AM »
hmm that might be hard.. i think the easiest way would be to put some sort of switch in beween a cheap 128mb mp3 player and some sort of trigger. maybe a break in the line? that would be wiked tho :) anyways i have done this before with a line follower and thats what i did. but i didnt have the knowledge i had today and i broke everything  >:( oh well...good luck
~smash
Offline Bubbles
« Reply #29 on: January 27, 2008, 05:08:23 AM »
first of all is to actually measure the wheels so that you can figure out if they are in fact big enough. to do this i would:
1. find out how far away the bottom of your wheels will be from the bottom part of the chassis (to be more accurate, do this mathematically instead of guestimation)
2. take that and minus the height of any objects under the chassis then the number left over is approximately the maximum height of an object you can drive over (as long as the objects' length is less than or equal to the length of the robot, otherwise it will just drive up it at an angle and it doesn't matter) i.e. rock, speed bump
3. funny third thing (yet to be implemented)  :P
if any of this is wrong pls tell me and i am srry but it is late  :P
Last post February 29, 2008, 02:34:43 PM
by ed1380
Last post January 09, 2010, 08:37:36 AM
Last post April 14, 2012, 09:29:31 PM
by dpmntrs
Last post December 26, 2011, 06:56:15 AM
by nik@sdm
