Author Topic: suggestions for charging batteries  (Read 3514 times)
Offline exl949Topic starter
« on: March 01, 2006, 01:16:45 AM »
ok, so i have plans for something, but i have one problem, my bot will be away for long periods of time, like weeks, and it will spend most of its time in a breezy environment, is there someting out there to charge the batteries using wind? its a dark environment too so solar is out of the question, i guess i havent been looking for the right thing so far. any suggestions?
thanks in advance..
Re: suggestions for charging batteries
« Reply #1 on: March 01, 2006, 08:01:11 AM »
hmmmm sounds like you got a tricky problem . . . look into mars rover technology as it is very similar to what you want . . .
you will probably need to consider all of these options, and possibly even a combination of them:
1) use a lot of batteries (calculate how much power you will need for 'weeks')
2) make your robot extremely power efficient
3) wind power generator . . .
making a wind power generator is very easy. it is just like hooking up solar panels to a battery for recharging it.
steps:
get a highly geared DC motor, make sure the gears are very efficient and new
attach a long blade fan to it
attach the ground wire of the motor to the ground of your battery
attach motor power wire to the + end of a diode
attach the - end of the diode to the positive end of your battery
the diode prevents the battery spinning the motor, so that power can only come out of the motor . . .
you will also have to consider how to shut down all your systems until your battery has been recharged again. consider a battery power monitor.
and you will probably have to lower the fan when your robot moves so as to not resist the movement . . .
can you have a recharge station?
Offline zamboniman60
« Reply #2 on: March 01, 2006, 10:12:08 PM »
Get some energizer lithium batteries as a backup. These batteries hold a lot of power, and can be used as a backup, maybe even as your main powersource. Consider getting a fuel cell kit (http://www.discoverthis.com/fuelcelcaran.html) and cannibalizing the cell; just use ant weight pneumatics (http://www.robotmarketplace.com/marketplace_ant_pneu.html) to store the hydrogen.
« Reply #3 on: March 01, 2006, 11:06:10 PM »
thanks admin! i will try that!
Offline jonas
« Reply #4 on: March 10, 2006, 11:38:16 PM »
here's a link to the technology of the mars rover http://marsrovers.jpl.nasa.gov/technology/
Last post December 11, 2007, 02:07:46 PM
Last post June 01, 2010, 05:50:02 AM
by z.s.tar.gz
Last post January 24, 2012, 06:49:27 PM
Last post March 14, 2011, 12:32:15 PM
