Author Topic: H-Bridge or Controller IC  (Read 2899 times)
Offline jailsellgrenTopic starter
« on: November 26, 2006, 08:50:21 PM »
Hey im going to be powering 2 ml-50's
http://www.robotmarketplace.com/marketplace_motorsmisc.html
would you reccomend an hbridge
http://www.lynxmotion.com/Product.aspx?productID=92&CategoryID=10
or should i buy an motor driver ic or 2 and put them in paralell for more current and run off those
or should i use this
http://www.pololu.com/products/pololu/0101/
thanks,    also , i will be using a 12 v 2000 mah nimh battery
ive read the tutorial on SoR about this but i want your reccomendation for my specific situation
Offline JonHylands
Re: H-Bridge or Controller IC
« Reply #1 on: November 26, 2006, 09:29:30 PM »
The Pololu h-bridge is only one amp per channel. The other is at least rated for 2 amps per channel, but even it isn't really enough -- the motor's stall rating is at 3.3 amps.
Ideally, you'd want a 5 amp per channel h-bridge, but its doubtful that your motors will ever hit stall current running a 2-wheel balancer.
- Jon
« Reply #2 on: November 26, 2006, 11:14:54 PM »
so build an hbridge or buy one
if buy one then post a link to a 5a dual channel one
Offline JonHylands
« Reply #3 on: November 27, 2006, 06:25:39 AM »
Last post October 19, 2007, 08:17:21 PM
Last post May 24, 2008, 06:30:12 PM
by JesseWelling
Last post April 13, 2009, 11:36:32 PM
by robomow
Last post October 21, 2012, 06:00:05 AM
by Batienzaxcore
