Author Topic: when i use hyperterminal to read my robot get gibberish.  (Read 3239 times)
Offline rox2007Topic starter
« on: January 24, 2008, 11:37:02 AM »
bW
׳SCZccFJLӑWWwWg3'6W76WgWfǒgbc"*
Wg7W'n'cW:;g◝gcccFϝƷcwjWM"g3ggbcsFWc7SW?BP۟(cWsJ̍ǒg"GW MWgƢ#8cG(c(cRcWwWM"WgBSBcSSCWNWLGMW Ʊ]*xbx(cs?s72Wg8GgG(c F
this is my output in hyperterminal
what did i do wrong
Offline neo01124
Re: when i use hyperterminal to read my robot get gibberish.
« Reply #1 on: January 24, 2008, 11:51:41 AM »
give us at least some details of what ur trying to do like what is being read, how its connected,etc.
in the meanwhile u could try ur hand at putty http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
it has better GUI than hyperterminal and IMO is better and easier to use than hyperterminal
Offline rgcustodio
« Reply #2 on: January 24, 2008, 12:00:15 PM »
yeah i second neo01124's comment.
provide more information
also does the baud settings of the sender and receiver match? (specially if auto-baud is not being used)
Offline JonHylands
« Reply #3 on: January 24, 2008, 12:04:16 PM »
Check your baud rate, check your settings (8N1), make sure you've got hardware flow control turned off, make sure you're doing TTL -> RS-232 conversion...
- Jon
« Reply #4 on: January 24, 2008, 12:06:17 PM »
i am trying to relate information about my robot through uart to my computer.
I get info from the robot, but it is not readable (shown above).
i'm using uart with baud settings 38400
Offline neo01124
« Reply #5 on: January 24, 2008, 12:12:09 PM »
reading this post might help, it has some general troubleshooting tips....
http://www.roboticsindia.com/modules.php?name=Forums&file=viewtopic&t=2826
by the way did u try putty and was the output with it same??
« Reply #6 on: January 24, 2008, 12:24:55 PM »
yes the output was the same
« Reply #7 on: January 24, 2008, 01:48:05 PM »
I 2nd JonHylands and rgcustodio, your baud rate is wrong somewhere.
Make sure the baud is set the same in the microcontroller software, on your PC hardware driver, and hyperterminal. Thats three different places - if you mess up one, all get messed up . . .
Offline pomprocker
« Reply #8 on: April 18, 2008, 12:29:43 PM »
I've gotten this when i've done too many printf's in one control loop in my code.
Offline paulstreats
  • Helpful? 20
« Reply #9 on: April 18, 2008, 03:36:29 PM »
yeah and without a delay between the puts or printf commands can mess up the buffer
Last post August 12, 2007, 08:06:51 PM
Last post June 08, 2010, 09:55:01 AM
by javila
Last post February 02, 2012, 12:50:00 PM
by newInRobotics
Last post September 24, 2012, 07:47:43 PM
by SlightlyNormal
