Author Topic: Is this battery "dead"  (Read 2261 times)
Offline gamefreakTopic starter
  • Robo-Enthusiast
« on: January 27, 2008, 09:33:23 PM »
I have an old 7.2 volt 1500 MaH battery here, and a multimeter reads 1.4 volts, is this battery in the doomed deep cycle?
Offline Trumpkin
Re: Is this battery "dead"
« Reply #1 on: January 28, 2008, 09:25:37 AM »
have you tried recharging it? also if you scroll about half way down this page http://blog.makezine.com/archive/make_podcast/2.html you will see joule thief you might be able to use that to get a little more life out of your battery. :)
Robots are awesome!
« Reply #2 on: January 31, 2008, 09:24:16 PM »
What type of battery?
Probably doomed, but I'd try to save it anyway. Just charge it up and see what happens . . .
  • Robo-Enthusiast
« Reply #3 on: February 03, 2008, 02:56:29 PM »
NiCD
I ripped off the plastic casing because it appeared that some wire insulation was falling off and the wires very close to touching, rewrapped it with ducttape, checked its voltage, .5 volts, put it on my charger at ~.75 amp hour, and it finished charging withen 20 minutes(should have taken two hours), and checked the voltage,it read 8.06 volts, seems very strange.....
I then switched over to amps and it measuered 1.5 amps, steadily dropped and I then stopped at .4 amps, switched back to volts, and the battery steadily rose from 5 volts to 6.6 volts when i stopped measuring, this battery is magic.....
« Last Edit: February 03, 2008, 03:01:28 PM by gamefreak »
« Reply #4 on: February 03, 2008, 05:47:49 PM »
The voltage on a battery isn't fixed. When it says 6V rating, that doesn't mean it is ever actually 6V. As a battery is drained, the voltage drops too.
The voltage is dependent on the internal charge level (measured in mAh). A battery that can't hold a charge (which effectively has a low mAh), will drop in voltage much faster.
I know some types of lead acid batteries can be 'saved' by charging and discharging it a few times (its a chemistry thing, too lazy to explain). NiCads however I'm not sure . . . worth looking up, or experimenting to find out . . . but I think your battery is dead . . .
Offline Trumpkin
« Reply #5 on: February 03, 2008, 05:58:52 PM »
yep definently dead, buy another one, all battery is having a sale http://www.all-battery.com/ .
Robots are awesome!
  • Robo-Enthusiast
« Reply #6 on: February 03, 2008, 06:08:09 PM »
If i set my multimeter on amps and and just connect it to the battery, will it give me the MaH?
Offline Trumpkin
« Reply #7 on: February 03, 2008, 06:09:02 PM »
depends on if your multimeter reads mah.
Robots are awesome!
Offline Maltaeron
« Reply #8 on: February 04, 2008, 07:52:24 AM »
It will be pretty obvious which one it is. VERY good batteries might have around 2 aH, or 2000 mAH. If yours is not in the decimal places, it is being measured in mAH. Also, next time grab some niMH batteries so that you don't have to worry about the memory effect of niCads.
« Reply #9 on: February 04, 2008, 08:12:37 AM »
For those who didnt catch trumpkin's clever sarcasm, no, you can't measure mAh with a multimeter. ;)
The way to do it is charge up the battery, put a current sensor data logger on it, and measure the current in time it supplies with a resistor across the leads.
Offline Trumpkin
« Reply #10 on: February 04, 2008, 01:04:39 PM »
I'm suprised no 1 else got my joke.
Robots are awesome!
Offline ed1380
« Reply #11 on: February 04, 2008, 03:02:25 PM »
o we got it all right.
Offline HDL_CinC_Dragon
« Reply #12 on: February 04, 2008, 05:48:45 PM »
aw crap I didnt notice hahaha
my mind automatically dropped the 'h' lol
United States Marine Corps
Infantry
Returns to society: 2014JAN11
Last post November 28, 2006, 09:08:18 AM
Last post July 31, 2007, 04:50:14 AM
Last post April 29, 2008, 02:49:01 PM
Last post July 30, 2010, 04:36:54 PM
by teoxan
