Author Topic: battery specifications  (Read 1920 times)
Offline junior000Topic starter
« on: January 28, 2008, 03:05:41 AM »
hi,
  need some clarification.
  if a battery storage capacity is 9v 2100mah,what does 2100mahh stand for???
view my tutorials at
www.myfirstbot.blogspot.com
Re: battery specifications
« Reply #1 on: January 28, 2008, 03:10:18 AM »
is the second one supposed to have 2 h's?
Offline robonoob
« Reply #2 on: January 28, 2008, 08:01:55 AM »
NO!
and that means that thiss battery can give 2100mA for an hour. if u use less amps then it will last longer. say you need 1050 amps, then the battery will last for 2 hours  etc :)
« Reply #3 on: January 28, 2008, 07:35:19 PM »
NO!
1050 ma not amps! that is some high current stuff
mah stands for milliamps hour , as robonoob said it can give 2100 milliamps continuously for a hour
Offline robonoob
« Reply #4 on: January 29, 2008, 11:27:11 AM »
oops :D yea thats what i ment. mAmps not Amps :)
Offline HDL_CinC_Dragon
« Reply #5 on: January 29, 2008, 12:44:14 PM »
Thats nothin'. I once bit into a 4 trillion amp wire just to see what would happen.... (holy crap imagine the wire thickness needed to contain that much amperage... it would have to have the same diameter as friggen Jupiter lol)
"mAh" = "Milliamp hours"
To find out how long said battery will last, there is a simple equation:
[battery-mAh-rating] / [circuit-mA-requirement] = [battery-life-in-hours]
« Last Edit: January 29, 2008, 12:45:44 PM by HDL_CinC_Dragon »
United States Marine Corps
Infantry
Returns to society: 2014JAN11
Offline karmax
« Reply #6 on: February 06, 2008, 01:28:17 AM »
 :) It simply means that if u takes 2100ma current from urs battery then it can run for 1 hour
Last post June 17, 2009, 06:28:47 PM
Last post June 19, 2009, 11:37:21 AM
by galannthegreat
Last post March 15, 2011, 04:28:42 PM
by tenrinho
Last post January 27, 2012, 01:16:07 AM
