Author Topic: precise range finder  (Read 2183 times)
Offline benjiTopic starter
« on: January 28, 2008, 08:42:10 AM »
hey guys, i was working on a project that should indicate ranges in terms of 1/10 milli-meters, so anybody knows such a range finder that can provide such great accuracy? the maximum range isnt necessary ,it can be 20 cm as a maximum
good ol' BeNNy
Offline krich
Re: precise range finder
« Reply #1 on: January 28, 2008, 04:19:55 PM »
I've been looking into rangefinders quite a bit these days.  Although my experience is largely theoretical, nothing that I've been looking at is that accurate.  I haven't been looking into Laser Rangefinders because of the cost.  That's the only thing I can think of that even has a chance of giving you the 1/10mm resolution.
On another note, those sensors in Optical Mice (Avago/Agilent ADNS-2051, for example), have a resolution of 400-1600 CPI.  That meets your requirement, but its not necessarily a "range finder", more like an encoder wheel substitute.  It would be able to measure the distance from point A to point B very very accurately.  The downside is that your robot would have to move from point A to point B to measure it.
Ken.
« Reply #2 on: January 28, 2008, 04:46:30 PM »
i cant get my bot to move there, no, that wont do
good ol' BeNNy
Offline JonHylands
« Reply #3 on: January 28, 2008, 04:58:21 PM »
As far as I know, the only way you could do that would be to have a physical connection between the robot and the object being sensed, and use a very accurate linear sensor.
- Jon
« Reply #4 on: January 28, 2008, 05:02:32 PM »
can lasers provide such precision?
good ol' BeNNy
Offline frank26080115
« Reply #5 on: January 28, 2008, 05:47:21 PM »
jackscrew + stepper motor + contact sensor
use your imagination
« Reply #6 on: January 29, 2008, 10:15:51 AM »
i just dnt want to contact anything
good ol' BeNNy
Offline Dank55
« Reply #7 on: January 29, 2008, 04:08:30 PM »
I posted this before, but the search engine isn't pulling it up, so here it is again:
"Phase-shift laser rangefinders" measure distance along a line of sight, and this gives them much better range and accuracy than ultrasonic or infrared rangefinders and proximity detectors. You can find lots of them for less than $100 on Amazon, but I'll just mention the specs on one as an example of what you can get for around $130: the Bosch DLE50. It's tiny (175g or 6 ounces, including batteries), has a range of 5cm to 50m (2 inches to 55 yards), and is accurate to within 1.5mm (0.06 inches) at a range of 30m or less. Lasers are notorious battery drainers, but that's not a killer: you can use other sensors until you need the greater accuracy and range. An annoying caveat is, I haven't yet found a cheap one with a data port, and the only one I've found with Bluetooth is over $600. But I expect this flaw will be remedied soon.
Dan
#wikiversity on irc.freenode.net
Dan, dank55 on gmail.com and Wikipedia
« Reply #8 on: January 29, 2008, 04:24:48 PM »
i need way more accuracy
anyways thank you guys for answering
good ol' BeNNy
« Reply #9 on: February 04, 2008, 05:25:44 PM »
benji . . . you are asking for insane precision . . . ;)
Yea the search engine is horrible. The advanced search feature helps a bit. And sometimes I have luck using the google search on the forum:
http://www.societyofrobots.com/robot_tutorial_index.shtml
« Reply #10 on: February 04, 2008, 05:40:04 PM »
its that i once saw a tv program adn they talked about some folks who did a 3d scanner for shapes
,its like a small fridge where you put somthing like a cup and you close the door
this thing scans the shap and draw it on the computer,, its a really amazing device
and the precision is very high, so i was guessing what presice sensors this thing is using ,thats all
good ol' BeNNy
Last post March 25, 2009, 01:41:42 PM
by SmAsH
Last post June 07, 2010, 05:18:00 AM
by Alfa_Zulu
Last post December 16, 2010, 05:14:07 AM
by abhimohpra
Last post March 21, 2012, 04:03:35 PM
by Dekabal
