Author Topic: humanid robot parts  (Read 4246 times)
Offline TrumpkinTopic starter
humanid robot parts
« on: January 28, 2008, 05:48:25 PM »
I might be making a humanoid robot like Robonova in the future and i was wondering what servos and microcontroller, hopefully under $70 you reccomend I use. If I make it the robot will probably use 12 servos total.
Robots are awesome!
Offline cooldog
Re: humanid robot parts
« Reply #1 on: January 28, 2008, 05:57:21 PM »
dude $70?
the $50 robot alone costs $100
servos are like $15 each
-admin
favorite web sites
http://www.instructables.com/
« Reply #2 on: January 28, 2008, 06:12:01 PM »
i meant $70 for microcontroller.
Robots are awesome!
« Reply #3 on: January 28, 2008, 06:15:22 PM »
Also, would I need digital servos?
Robots are awesome!
« Reply #4 on: January 29, 2008, 01:38:09 PM »
I found this microcontroller, it looks pretty good how many servos can it handle? could I use AVR studio compiler? http://gumstix.com/store/catalog/product_info.php?products_id=139
Robots are awesome!
« Reply #5 on: January 29, 2008, 03:53:02 PM »
Could I use HS-311 serovs? I found this gyroscope http://www.trossenrobotics.com/store/p/4915-KRG-3-Gyroscopic-Sensor.aspx?feed=Froogle The cheapest one I could find, does it look good?
Robots are awesome!
Offline krich
« Reply #6 on: January 29, 2008, 04:40:41 PM »
Well, the RoboStix uses the AVR ATmega128, so I'd say that it's a sure bet to use it with AVR Studio.
Here's the specs from the GumstixDocsWiki:
    * ATmega128 AVR processor at 16MHz
    * 30 AVR GPIO lines at 5V
          o 6 optionally function as 16-bit PWM outputs
          o 8 optionally function as 8 or 10-bit ADC
    * 2 AVR UARTs at 5V
    * 2 Gumstix UARTs at 5V (STUART and FFUART, when used in conjunction with a Gumstix module only)
    * Shared I2C bus for communication between the AVR and an attached Gumstix module, and control of external devices
    * ISP connector for programming AVR (can also be programmed by an attached Gumstix module)
    * Power Jack (5.5V+) or separate headers for logic and servo power
Try going here:  Robostix for more information, particularly the Intro and the FAQ
With 30 GPIO, I'd say it could handle 12 servos easily, even double that number.
Offline paulstreats
  • Helpful? 20
« Reply #7 on: January 29, 2008, 06:35:18 PM »
I woulld just use 1 microcontroller for controlling the servos (programmed for the walking gaits), and then use another mcu to tell that one what to do. mcu's cost like $6 or even less.
The servos are going to be the killer cost so work out what you really do need and what you dont.
Have you got any ideas in mind for how the servos are set up? can we have some cad pictures just for our viewing pleasure? TA ;D
« Reply #8 on: January 29, 2008, 08:54:02 PM »
sure, i'll try to get some CAD pictures up. I'm kinda busy so I don't know when they will get done. I have thought out servo placement and have figured that i will need 15 servos. 3 of which I already have. can some 1 please just tell me how many servos robostix can handle?thx
Robots are awesome!
« Reply #9 on: January 29, 2008, 09:15:41 PM »
make that 17 servos two to rotate the legs. does any 1 know how to put an axle on to a servo?
« Last Edit: January 29, 2008, 09:16:46 PM by Trumpkin »
Robots are awesome!
« Reply #10 on: January 30, 2008, 02:56:23 PM »
here is a CAD of 1 leg of the robot. It is not to scale
« Last Edit: January 30, 2008, 03:06:02 PM by Trumpkin »
Robots are awesome!
« Reply #11 on: January 30, 2008, 03:00:38 PM »
I jsut noticed the CAD is a little messed up I will try to fix it.
Robots are awesome!
« Reply #12 on: January 31, 2008, 09:51:11 AM »
A more complete CAD but is still missing arms.  please keep in mind these are just very rough sketches
« Last Edit: January 31, 2008, 09:52:26 AM by Trumpkin »
Robots are awesome!
Offline robonoob
« Reply #13 on: January 31, 2008, 12:43:30 PM »
hey man sorry i dont have nything usefull to say to you ,but DO NOT make double posts(woops sorry its 5-posts in a row)
read this: http://www.societyofrobots.com/robotforum/index.php?topic=1480.msg10359#msg10359
the first sentence :)
dont be mad at me but i just had to say this :)
« Reply #14 on: January 31, 2008, 01:16:43 PM »
yeah, woops srry, nobody seems to be replying though. I'll try not to. srry everybody....especially Admin ::)
« Last Edit: January 31, 2008, 01:38:55 PM by Trumpkin »
Robots are awesome!
Offline cooldog
« Reply #15 on: January 31, 2008, 03:25:34 PM »
remember if there is something you let out there is a little modify button ontop of your posts
-admin
favorite web sites
« Reply #16 on: February 01, 2008, 09:25:31 AM »
I really need some help on which microcontroller to use. It needs to be able to control 17 servos and atleast 2 sensors. could I just connect 2 robotstix?
« Last Edit: February 01, 2008, 12:37:31 PM by Trumpkin »
Robots are awesome!
« Reply #17 on: February 01, 2008, 12:44:01 PM »
just get a separate servo controller for those 17 servos , and have your master MCU send serial commands which translate into servo commands
« Reply #18 on: February 01, 2008, 12:47:13 PM »
how would you do that?
Robots are awesome!
« Reply #19 on: February 01, 2008, 02:01:11 PM »
oh sorry Krich didn't see that
Robots are awesome!
Offline Rebelgium
« Reply #20 on: February 02, 2008, 01:10:06 PM »
Trumpkin you just double posted again.
There is a little button on the right of your last reply called "modify", use it to add or change something to your last reply if noone else has replied.
And replying to get your topic back up in the forum to get more replies is not allowed. It is generally the rule you have to wait 24 hours before you double post if noone else has replied.
orgcrime.net
« Reply #21 on: February 02, 2008, 08:34:12 PM »
I didn't know that rule I know about the modify button.
Robots are awesome!
« Reply #22 on: February 04, 2008, 11:03:26 PM »
The reason I am developing my Axon microcontroller is honestly there aren't any good biped controllers out there . . . (sorry, shameless plug!) . . . but you may have to wait a bit, and its out of your budget . . .
Anyway, you will be hard pressed to find a controller that does more than 16 servos.
Offline JonHylands
« Reply #23 on: February 05, 2008, 06:15:50 AM »
Well, maybe other than this one...
http://www.lynxmotion.com/Product.aspx?productID=395
- Jon
« Reply #24 on: February 05, 2008, 09:18:15 AM »
that looks good but it can't have sensors can it? is there some way I could connect it to a master controller or something? if so how could I do it?
Robots are awesome!
« Reply #25 on: February 05, 2008, 09:32:34 AM »
You would have to use either a computer or another microcontroller to interface it through RS-232 or TTL (using UART).
So what I meant to say was, "you will be hard pressed to find a single board controller that does more than 16 servos." ;D
« Reply #26 on: February 05, 2008, 09:46:40 AM »
is there a website that would tell me how to do that?
Robots are awesome!
Last post July 06, 2009, 12:38:56 AM
by SmAsH
Last post March 10, 2010, 07:59:31 PM
by GWER57
Last post June 12, 2010, 12:28:37 PM
by Hal_Emmerich
Last post October 26, 2010, 11:53:18 AM
by morglum
