Author Topic: Motor Drive and $50 robot  (Read 1912 times)
Offline MicHaeLTopic starter
« on: January 29, 2008, 09:24:26 AM »
Hi
I am building the $50 robot this isn't my first robot so i got some of these chips
http://www.solarbotics.com/assets/documentation/kit10.pdf
and i was wondering if i could us these plus a normal geared motor instead of the modified servos.
and how would i need to modify them to be able to be mated with the 3 pins on the $50 robots cercit bored.
MicHaeL
« Last Edit: January 29, 2008, 09:26:49 AM by MicHaeL »
MicHaeL
Offline Trumpkin
Re: Motor Drive and $50 robot
« Reply #1 on: January 29, 2008, 09:30:51 AM »
hmmm you might be able to. but the question is, is it worth all the hard work when you could just get a servo?
Robots are awesome!
Offline robonoob
« Reply #2 on: January 29, 2008, 11:56:39 AM »
umm if i understand yourplan correctly then you wont need to do that(modify them to be able to be mated with the 3 pins on the $50 robots cercit bored)
you will need an h-brigdge. i cant tell you anything about the circuit board wiring cuz i dont know much of it but yea read this: http://www.societyofrobots.com/schematics_h-bridgedes.shtml
it may be difficult to understand at the beginning(at least it was for me) but i understand it completely, just look for some robots that use the h-bridge and you will too :)
« Reply #3 on: January 29, 2008, 02:13:28 PM »
you would need to change the code of the software for the $50 robot , so I would suggest getting servos
Change the code, and change the headers since it would be just output onto the H bridge
Offline ed1380
« Reply #4 on: January 29, 2008, 02:44:28 PM »
very easy. get an ESC. you wont even need to modify the code. but make sure to get the right one. cause brushless and brushed ESC are diferent
« Reply #5 on: January 30, 2008, 04:15:21 AM »
ok thanks i think the ill just go withthe modifyed servo sounds the simpiler and less expensive root.
but any way thanks for the help.
MicHaeL
MicHaeL
Last post September 25, 2008, 12:15:54 PM
by Trumpkin
Last post September 14, 2009, 03:33:34 AM
by radhoo
Last post April 24, 2010, 07:47:28 AM
by Cristi_Neagu
Last post May 17, 2010, 03:32:38 AM
by Actives
