Author Topic: Simple programming help  (Read 3523 times)
Offline SciOlyStudentTopic starter
« on: January 29, 2008, 04:15:59 PM »
I need to program a robot to move forward for a certain amount of time and then stop.  I was thinking I could take the 50$ robot program and just delete everything, then putting in for it to move straight and then delay a certain amount of time.  I have no programming experience whatsoever.  Can someone fill in the blanks for me?
Offline benji
Re: Simple programming help
« Reply #1 on: January 29, 2008, 05:21:28 PM »
1/turn motors on
2/delay
3/motors off(you can give it a reverse voltage if its dc motor for a short amount of time as a break)
good ol' BeNNy
« Reply #2 on: January 29, 2008, 05:22:36 PM »
Sorry, I forgot to say I was using servos... what command would I give the microcontroller to make the servos stop?
Offline benji
« Reply #3 on: January 29, 2008, 05:27:24 PM »
you just tell e servo to go to a specific angle, and when its there it stops, did you modify ur sercos to make full turns?
good ol' BeNNy
« Reply #4 on: January 29, 2008, 05:54:14 PM »
I did modify the servos for full rotations.  Now I have another problem... when I try to write the program I substituted for the photovore program, it wouldn't write... It says the device is missing or there is an unknown device.  Any solutions?
Offline ed1380
« Reply #5 on: January 29, 2008, 06:10:44 PM »
search. million threads with the same question
Offline cooldog
« Reply #6 on: January 29, 2008, 08:47:01 PM »
won't you need encoders
-admin
favorite web sites
http://www.instructables.com/
Offline Trumpkin
« Reply #7 on: January 30, 2008, 11:30:43 AM »
how do you turn servos off?
Robots are awesome!
Offline ed1380
« Reply #8 on: January 30, 2008, 02:42:35 PM »
stop sending the pulse
Offline Trumpkin
« Reply #9 on: January 30, 2008, 02:43:41 PM »
lol ok, thx
Robots are awesome!
« Reply #10 on: January 30, 2008, 04:49:17 PM »
At first, I thought so too, but I'm going to run tests to see how long it takes the robot to travel a distance and then just make the program delay that long and then stop the servos
« Reply #11 on: January 30, 2008, 06:46:42 PM »
this might work  HOWEVER it will only be accurate if power to the servo is the same all the time , the same weight of robot , and the same surface.
« Reply #12 on: January 30, 2008, 07:42:46 PM »
Hmmm... I've thought of the last two and they don't matter (always the same weight on a flat, smooth surface), but the power one concerns me... won't a servo run at the same speed you tell it to despite low battery power?
« Reply #13 on: January 30, 2008, 07:48:47 PM »
well the servo will run slower with less power , im assuming since it is a DC motor inside
maybe this calls for a switching regulator for each servo?
« Reply #14 on: January 30, 2008, 07:53:15 PM »
At any rate, all I have to do is run the tests for my robot with fully charged batteries, the same for the competition.  It only has to go a maximum of 10 meters...
« Reply #15 on: January 30, 2008, 09:22:06 PM »
ok but make sure the batteries are fully charged when you test it and after each run
if you use a voltage regulator ( a switching one, not a regulated one) then you can regulate the amount of voltage that they draw
use one regulator per servo .
Also, what is the voltage all the batteries, how many AAs or whatever battery you are using?
« Reply #16 on: January 31, 2008, 05:07:14 PM »
Regular AAs... I know I know, its a waste but the competition limits me to using no more than 4 batteries at a maximum of 1.5V each... I would use NiMH except I couldn't find one with a voltage higher than 1.2V and I need 6V.
Offline ed1380
« Reply #17 on: January 31, 2008, 05:18:42 PM »
rechargable AA are 1.2v  ;D
Last post June 03, 2007, 12:32:17 PM
by bardlund
Last post February 17, 2008, 09:40:01 AM
Last post July 24, 2008, 09:01:24 PM
by airman00
Last post February 06, 2009, 12:55:43 PM
by galannthegreat
