Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
November 20, 2009, 09:27:06 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Search:
Advanced search
Sept 30th - The
5th SoR Robot contest
is now open! Win an Axon II!
Robot Forum
72,665
Posts in
9,267
Topics by
5,290
Members
Latest Member:
robertelson
Robot Forum
Electronics
Electronics
6-channel Futaba R/C receiver and ATmega32 communication
Pages:
1
Author
Topic: 6-channel Futaba R/C receiver and ATmega32 communication (Read 1969 times)
Tsukubadaisei
Robot Overlord
Helpful? 0
Offline
on:
January 31, 2008, 04:22:48 AM »
Hi, I need some help/advise.
My team and I am building a half-robot half-R/C airship. It is going to be programmed so that it is autonomous(auto-pilot) while there is no input from the R/C transmiter and if there is input then it will obey this input. For the auto-pilot we are using some ultra-sonic PSD sensors and a acceleration sensor. For the controlling unit we are using the ATmega32. Finally for movement we are using 3 DC motors connected to an usual one-chip toshiba motor controller. So far so good.
The problem starts here: I would like to know how could I connect the Receiver to the Atmega. Which port should I use for input? What kind of programming should I do(if possible source code please)? Besides the controller and the receiver, which hardware should I add?
For reference here are the things I know/researched already(yes I do my homework):
1)I know that the receiver is used for controlling servos so it will output a PWM wave. Then I must be able read this PWM in order to turn off the auto-pilot and control the 3 DC motors. I would like to know some sort of algorism to do that efficiently. If possible the source for the ATmega32/Arduino
or compatible controllers.
2)I talked with a friend of mine who already have done this kind of stuff but using the ATmega88 and he gave me the source code of his robot. His robot is much simpler than ours(no auto-pilot or sensing devices). But I would like to know do you guys think about it.(the guy is Japanese so the comments are in Japanese sorry(m-_-m)).
Code:
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#include <stdlib.h>
#include <ctype.h>
#include <stdio.h>
#include <math.h>
//マクロ
#define cbi(addr,bit) (addr &= ~(1<<bit))
#define sbi(addr,bit) (addr |= (1<<bit))
#define RTC_COMPARE
50000
#define PRP_STICK_R_X
5
#define PRP_STICK_R_Y
3
#define PRP_STICK_L_X
2
#define PRP_STICK_L_Y
4
#define PRP_SWITCH
1
#define PRP_VOLUME
0
#define PRP_STICK_R_X_CENTER
237
#define PRP_STICK_R_Y_CENTER
237
#define PRP_STICK_L_X_CENTER
237
#define PRP_STICK_L_Y_CENTER
237
#define PRP_STICK_R_X_PLUS
301
#define PRP_STICK_R_Y_PLUS
173
#define PRP_STICK_L_X_PLUS
302
#define PRP_STICK_L_Y_PLUS
174
#define PRP_STICK_R_X_MINUS
172
#define PRP_STICK_R_Y_MINUS
302
#define PRP_STICK_L_X_MINUS
172
#define PRP_STICK_L_Y_MINUS
301
#define MEDIAN_FILTER_ELEMENTS
4
#define MOTOR_CH0_BRAKE
0x03
#define MOTOR_CH0_CW
0x01
#define MOTOR_CH0_CCW
0x02
#define MOTOR_CH0_FREE
0x00
#define MOTOR_CH1_BRAKE
0x30
#define MOTOR_CH1_CW
0x10
#define MOTOR_CH1_CCW
0x20
#define MOTOR_CH1_FREE
0x00
#define MOTOR_CH2_BRAKE
0x0c
#define MOTOR_CH2_CW
0x04
#define MOTOR_CH2_CCW
0x08
#define MOTOR_CH2_FREE
0x00
#define MOTOR_CH0
0
#define MOTOR_CH1
1
#define MOTOR_CH2
2
//構造体
typedef struct time_t{
uint8_t second;
uint8_t accumulator_byte;
uint8_t minute;
uint8_t hour;
uint16_t m_second;
uint32_t accumulator;
}time_t;
typedef struct propo_pulse_t{
uint16_t old_time;
uint16_t def_time;
}propo_pulse_t;
typedef struct motor_state_t{
uint8_t level;
uint8_t direction;
uint8_t level_buffer;
uint8_t direction_buffer;;
}motor_state_t;
typedef struct encoder_state_t{
uint8_t accumulator_byte_def;
uint16_t counter_def;
}encoder_state_t;
//グローバル変数
volatile time_t time;
volatile propo_pulse_t propo_pulse[6];
volatile uint16_t g_debug;
volatile motor_state_t motor_state[3];
volatile encoder_state_t encoder_state[3];
volatile uint8_t system_enable;
//プロトタイプ
void SCI_open(uint16_t bps_value);
void SCI_write(uint8_t tx);
uint8_t SCI_read(void);
void SCI_transmit_string(char *string);
void wait_msec(uint16_t term);
char *sitoa(uint16_t data,char *s);
int16_t prp_get_pulse_width(uint8_t channel);
void set_motor_power(uint8_t channel,int16_t level);
//uint16_t get_motor_speed(uint8_t channel);
//回転数を取得
//回転方向は分からない
#define get_motor_speed(channel) (uint16_t)(937500 / ((uint32_t)encoder_state[channel].counter_def + (uint32_t)encoder_state[channel].accumulator_byte_def * RTC_COMPARE))
void motor_speed_control(int16_t speed);
//cal 144
//添え字とプロポの各チャネルの対応
//0
ch6 右上のフラップ
//1 ch5 左上のギア
//2 左スティックのx
//3 右スティックy
//4 左スティックy
//5 右スティックx
//パルス幅データは生の値を128で除した値を使う
//各モータチャネルとポートの対応
//motor ch0 マイコンより
PB0,PB1
//motor ch1 真中
PD4,PD5
//motor ch2 一番外側
PD2,PD3
//ch0
右舷モータ
プロポRY
//ch1
左舷モータ
プロポLY
//ch2
上昇モータ
プロポRX
//ドライバファンクション
// L L FREE
// L R or R L CW/CCW
// H H Brake
//タイマ2オーバーフロー割り込み
//ソフトウエアPWMの処理
//面倒だからFreePWMでいいや
ISR (TIMER2_OVF_vect){
static uint8_t base_counter;
if(system_enable == 0){
PORTB &= 0xFC;
//全OFF
PORTD &= 0xC3;
return;
--base_counter;
if(base_counter == 0){
PORTB &= 0xFC;
//全OFF
PORTD &= 0xC3;
motor_state[MOTOR_CH0].level_buffer = motor_state[MOTOR_CH0].level;
//値更新
motor_state[MOTOR_CH1].level_buffer = motor_state[MOTOR_CH1].level;
motor_state[MOTOR_CH2].level_buffer = motor_state[MOTOR_CH2].level;
motor_state[MOTOR_CH0].direction_buffer = motor_state[MOTOR_CH0].direction;
motor_state[MOTOR_CH1].direction_buffer = motor_state[MOTOR_CH1].direction;
motor_state[MOTOR_CH2].direction_buffer = motor_state[MOTOR_CH2].direction;
}else{
if(base_counter == motor_state[MOTOR_CH0].level_buffer){
PORTB = (PORTB & 0xFC) | motor_state[MOTOR_CH0].direction_buffer;
if(base_counter == motor_state[MOTOR_CH1].level_buffer){
PORTD = (PORTD & 0xCF) | motor_state[MOTOR_CH1].direction_buffer;
if(base_counter == motor_state[MOTOR_CH2].level_buffer){
PORTD = (PORTD & 0xF3) | motor_state[MOTOR_CH2].direction_buffer;
#define P_GAIN
13
#define I_GAIN
2
#define CONTROL_VALUE_SCALE 2000
//回転数制御をPIコントローラで行う
//制御周期50msec
//回転数の指定はrpmで行う
//回転数の値の正負で正転逆転を指定する
void motor_speed_control(int16_t speed){
uint16_t feed_back_speed;
int32_t error;
int32_t control_value;
static int32_t error_old = 0;
static int32_t control_value_old = 0;
int32_t buf;
feed_back_speed = get_motor_speed(MOTOR_CH0);
error = speed - feed_back_speed;
control_value = P_GAIN * error + I_GAIN * (error + error_old);
control_value /= CONTROL_VALUE_SCALE;
buf = control_value;
//if( ((control_value > 0) && (speed < 0)) || ((control_value < 0) && (speed > 0)) ){
//control_value = 0;
if(buf < 0){
buf = 0;
control_value += control_value_old;
set_motor_power(MOTOR_CH0,control_value);
error_old = error;
control_value_old = control_value;
int main(void){
char tx_buffer[80];
int16_t pulse_buffer[6];
volatile double theta;
int16_t r;
int16_t angle_int;
int16_t power_r;
int16_t power_l;
//ポートの設定
//DDRxが1で出力
DDRB = 0x03;
DDRD = 0x3C;
//入力のときにPORTを1にするとプルアップが有効になる
PORTB = 0xff;
PORTC = 0xff;
PORTD = 0xff;
//PCINT8-13を使ってパルスデコード
//PCINT22,23はそれぞれmotor ch0,1のエンコーダ入力
//PCINT2はmotor ch2のエンコーダ入力
PCICR = 0x07;
//PCINT8-14のピン変化割り込みを許可
PCMSK1 = 0x3f;
//PCINT8-13のみ割り込み有効
PCMSK0 = 0x04;
PCMSK2 = 0xC0;
//タイマ0は超音波信号40KHzの生成に使用
//16ビットタイマを使ってリアルタイムクロックを動かす
//タイマ1の設定
//プリスケーラ無し
//コンペア周波数 400Hz
TCCR1A = 0x04;
//比較一致タイマ コンペアレジスタOCR1A
TCCR1B = 0x09;
//PS1 CTC
ps1からps64に変更2116
OCR1A = RTC_COMPARE-1;
TIMSK1 = 0x02;
//コンペア割り込み許可
//タイマ2の設定
//オーバーフロー割り込みをかける
//割り込み周波数78.125kHz
TCCR2A = 0x00;
//CTC動作
TCCR2B = 0x01;
//プリスケーラ1/1
OCR2A = 250-1;
//コンペア周期設定
TIMSK2 = 0x01;
//コンペアA割り込み許可
sei();
//全割り込み許可
SCI_open(10);
motor_state[0].direction = MOTOR_CH0_CW;
motor_state[0].level = 125;
motor_state[1].direction = MOTOR_CH1_CW;
motor_state[1].level = 0;
motor_state[2].direction = MOTOR_CH2_CCW;
motor_state[2].level = 0;
//set_motor_power(MOTOR_CH0,-10);
//SCI_transmit_string('Hello!\n');
SCI_write('1');
SCI_write('2');
SCI_write('3');
SCI_write('4');
while(1){
pulse_buffer[PRP_STICK_R_X] = prp_get_pulse_width(PRP_STICK_R_X);
pulse_buffer[PRP_STICK_R_Y] = prp_get_pulse_width(PRP_STICK_R_Y);
pulse_buffer[PRP_STICK_L_X] = prp_get_pulse_width(PRP_STICK_L_X);
pulse_buffer[PRP_STICK_L_Y] = prp_get_pulse_width(PRP_STICK_L_Y);
pulse_buffer[PRP_SWITCH] = prp_get_pulse_width(PRP_SWITCH);
pulse_buffer[PRP_VOLUME] = prp_get_pulse_width(PRP_VOLUME);
system_enable = pulse_buffer[PRP_SWITCH];
sprintf(tx_buffer,"ch0 %d ch1 %d ch2 %d ch3 %d ch4 %d ch5 %d\n",
pulse_buffer[0],pulse_buffer[1],pulse_buffer[2],
pulse_buffer[3],pulse_buffer[4],pulse_buffer[5]);
SCI_transmit_string(tx_buffer);
//sprintf(tx_buffer,"sw = %d vol = %d",propo_pulse[PRP_VOLUME].def_time>>5,propo_pulse[PRP_SWITCH].def_time>>5);
//SCI_transmit_string(tx_buffer);
wait_msec(30);
//直行座標を極座標に変換する
//上手くいってない
theta = atan2(pulse_buffer[PRP_STICK_L_Y],pulse_buffer[PRP_STICK_L_X]);
r = sqrt((uint32_t)pulse_buffer[PRP_STICK_L_Y] * (uint32_t)pulse_buffer[PRP_STICK_L_Y] +
(uint32_t)pulse_buffer[PRP_STICK_L_X] * (uint32_t)pulse_buffer[PRP_STICK_L_X]);
angle_int = theta * 100;
//sprintf(tx_buffer,"r = %d theta =%d\n",r,angle_int);
//sprintf(tx_buffer,"r = %lf theta =%lf\n",r,theta);
power_r = 1.5*r * cos(theta - 3.141592 / 4);
power_l = 1.5*r * sin(theta - 3.141592 / 4);
sprintf(tx_buffer,"power_r = %d power_l = %d",power_r,power_l);
set_motor_power(MOTOR_CH0,power_r);
set_motor_power(MOTOR_CH1,power_l);
set_motor_power(MOTOR_CH2,-pulse_buffer[PRP_STICK_R_Y]);
sprintf(tx_buffer,"ch3 %d\n",propo_pulse[3].def_time);
wait_msec(30);
//SCI_write('a');
//直行座標を極座標に変換する
//上手くいってない
r = sqrt(pulse_buffer[PRP_STICK_L_Y] * pulse_buffer[PRP_STICK_L_Y] +
pulse_buffer[PRP_STICK_L_X] * pulse_buffer[PRP_STICK_L_X]);
power_r = r * cos(theta - 3.141592 / 4);
power_l = r * sin(theta - 3.141592 / 4);
sprintf(tx_buffer,"ch0 %d rpm\n",get_motor_speed(MOTOR_CH0));
wait_msec(5);
motor_speed_control(3000);
for(;;);
return 0;
//モータのPWMに値をセットする
//レベルの範囲は-255 ~ 255 まで
//レベルが正で正転 負で逆回転
//レベル範囲がおかしいときは上限、加減でリミットさせる
void set_motor_power(uint8_t channel,int16_t level){
int16_t abs;
if(level < -255){
//上下限リミット
level = -255;
}else if(level > 255){
level = 255;
if(level < 0){
//絶対値を得る
abs = -level;
}else{
abs = level;
switch (channel){
case MOTOR_CH0:
motor_state[MOTOR_CH0].level = abs;
if(level > 0){
motor_state[MOTOR_CH0].direction = MOTOR_CH0_CW;
}else{
motor_state[MOTOR_CH0].direction = MOTOR_CH0_CCW;
break;
case MOTOR_CH1:
motor_state[MOTOR_CH1].level = abs;
if(level > 0){
motor_state[MOTOR_CH1].direction = MOTOR_CH1_CW;
}else{
motor_state[MOTOR_CH1].direction = MOTOR_CH1_CCW;
break;
case MOTOR_CH2:
motor_state[MOTOR_CH2].level = abs;
if(level > 0){
motor_state[MOTOR_CH2].direction = MOTOR_CH2_CW;
}else{
motor_state[MOTOR_CH2].direction = MOTOR_CH2_CCW;
break;
#define PRP_PULSE_WIDTH_UPPER_LIMIT
300
#define PRP_PULSE_WIDTH_LOWER_LIMIT
-300
#define PRP_PULSE_WIDTH_NO_EFFECT_RANGE 20
#define PRP_PULSE_WIDTH_CENTER
950
#define PRP_PULSE_WIDTH_SWITCH_THRESHOLD
1000
#define PRP_PULSE_WIDTH_VOLUME_LOWER
610
//プロポのパルス幅を-255から255に丸めた値を返す
//パルス幅が異常なときは0を返す
//不感帯の処理も施す
int16_t prp_get_pulse_width(uint8_t channel){
int16_t buf;
int16_t abs;
buf = propo_pulse[channel].def_time>>5;
//return buf;
if(channel == PRP_SWITCH){
if(buf > PRP_PULSE_WIDTH_SWITCH_THRESHOLD){
return 1;
}else{
return 0;
}else if(channel == PRP_VOLUME){
buf -= PRP_PULSE_WIDTH_VOLUME_LOWER;
if(buf < 0){
buf = 0;
return buf>>2;
buf -= PRP_PULSE_WIDTH_CENTER;
//原点へ移動
switch(channel){
case PRP_STICK_R_Y:
case PRP_STICK_L_Y:
buf = -buf;
if((buf > PRP_PULSE_WIDTH_UPPER_LIMIT) || (buf < PRP_PULSE_WIDTH_LOWER_LIMIT) ){
return 0;
if(buf < 0){
abs = -buf;
}else{
abs = buf;
if(abs < PRP_PULSE_WIDTH_NO_EFFECT_RANGE){
return 0;
if(buf > 0){
if(buf > 255){
buf = 255;
return buf;
}else{
if(buf < -255){
buf = -255;
return buf;
int16_t buf;
int16_t abs;
//return buf;
return 0;
if(buf < 0){
abs = -buf;
}else{
abs = buf;
return 0;
if(buf > 0){
if(buf > 255){
buf = 255;
return buf;
}else{
if(buf < -255){
buf = -255;
return buf;
//タイマ1コンペア割り込み
//割り込み周波数400Hz
ISR (TIMER1_COMPA_vect){
static uint8_t divider_second;
time_t *p;
p = &time;
p->accumulator_byte++;
if(++divider_second >= 4){
divider_second = 0;
//100Hzで実行される行
p->m_second += 10;
p->accumulator += 10;
if(p->m_second >= 1000){
p->m_second = 0;
//1Hzで実行される行
if(++p->second >= 60){
p->second = 0;
if(++p->minute >= 60){
p->minute = 0;
if(++p->hour >= 24){
p->hour = 0;
//ロータリーエンコーダch0,1の割り込み
//立ちあがりでシステム時間をストアする
ISR (PCINT2_vect){
static uint8_t port_state_old;
static uint8_t accumulator_byte_old;
static uint16_t counter_old;
uint8_t accumulator_byte_store;
uint16_t counter_store;
uint8_t port_state_now;
uint8_t pulse_state;
uint8_t accumulator_def;
port_state_now = PIND;
pulse_state = (~port_state_old) & port_state_now;
if((pulse_state & 0x40) != 0){
//ch0立ち上がり検出
//SCI_write('@');
accumulator_byte_store = time.accumulator_byte;
counter_store = TCNT1;
//現在時刻保存
//コンペアフラグが立ってたら
if(bit_is_set(TIFR1,OCF1A)){
accumulator_byte_store++;
//前回との差をとる
//def = store - old
//下位の処理
if(counter_store > counter_old){
counter_def = counter_store - counter_old;
}else{
counter_def = RTC_COMPARE - counter_old + counter_store;
accumulator_byte_old++;
//桁下がりがあったから上位から引く
//上位の処理
accumulator_def = accumulator_byte_store - accumulator_byte_old;
//格納
encoder_state[MOTOR_CH0].accumulator_byte_def = accumulator_def;
encoder_state[MOTOR_CH0].counter_def = counter_def;
accumulator_byte_old = accumulator_byte_store;
//時刻保存
counter_old = counter_store;
port_state_old = port_state_now;
//状態保存
//パルスデコード
//パルス立ち上がりエッジのシステム時間と立下りエッジのシステム時間をそれぞれストアする
ISR (PCINT1_vect){
uint8_t pulse_def;
port_state_now = PINC;
//SCI_write('P');
pulse_def = (~port_state_old) & port_state_now;
if(pulse_def & 0x01){
//アタックのビットが立ったところに現在時刻をストア
propo_pulse[0].old_time = counter_store;
if(pulse_def & 0x02){
propo_pulse[1].old_time = counter_store;
if(pulse_def & 0x04){
propo_pulse[2].old_time = counter_store;
if(pulse_def & 0x08){
propo_pulse[3].old_time = counter_store;
if(pulse_def & 0x10){
propo_pulse[4].old_time = counter_store;
if(pulse_def & 0x20){
propo_pulse[5].old_time = counter_store;
pulse_def = (~port_state_now) & port_state_old;
//データ更新
//リリースのビットが立ったところで時間の差をとって格納
if(counter_store > propo_pulse[0].old_time){
propo_pulse[0].def_time = counter_store - propo_pulse[0].old_time;
}else{
propo_pulse[0].def_time = RTC_COMPARE - propo_pulse[0].old_time + counter_store;
if(counter_store > propo_pulse[1].old_time){
propo_pulse[1].def_time = counter_store - propo_pulse[1].old_time;
}else{
propo_pulse[1].def_time = RTC_COMPARE - propo_pulse[1].old_time + counter_store;
if(counter_store > propo_pulse[2].old_time){
propo_pulse[2].def_time = counter_store - propo_pulse[2].old_time;
}else{
propo_pulse[2].def_time = RTC_COMPARE - propo_pulse[2].old_time + counter_store;
if(counter_store > propo_pulse[3].old_time){
propo_pulse[3].def_time = counter_store - propo_pulse[3].old_time;
}else{
propo_pulse[3].def_time = RTC_COMPARE - propo_pulse[3].old_time + counter_store;
if(counter_store > propo_pulse[4].old_time){
propo_pulse[4].def_time = counter_store - propo_pulse[4].old_time;
}else{
propo_pulse[4].def_time = RTC_COMPARE - propo_pulse[4].old_time + counter_store;
if(counter_store > propo_pulse[5].old_time){
propo_pulse[5].def_time = counter_store - propo_pulse[5].old_time;
}else{
propo_pulse[5].def_time = RTC_COMPARE - propo_pulse[5].old_time + counter_store;
void wait_msec(uint16_t term){
uint32_t store;
volatile uint8_t dummy;
store = time.accumulator + (uint32_t)term;
while(time.accumulator < store){
dummy++;
void SCI_open(uint16_t bps_value){
UBRR0 = bps_value;
//ボーレートセット
sbi(UCSR0B,TXEN0);
//送信許可
sbi(UCSR0B,RXEN0);
void SCI_write(uint8_t tx){
while (!(UCSR0A & (1<<UDRE0)) );
if(tx == 0){
tx = '_';
//NULL置き換え
UDR0 = tx;
uint8_t SCI_read(void){
//while ( !(UCSR0A & (1<<RXC0)) );
return UDR0;
void SCI_transmit_string(char *string){
while(*string){
SCI_write(*string++);
SCI_write('\n');
SCI_write('\r');
//数値をアスキー文字列に変換
//ゼロサプレス有り
//ゼロはスペースに変換される
char *sitoa(uint16_t data,char *s){
char zf,c;
char *head = s;
zf=0;
c='0';
while(data>=10000){
data -= 10000;
c++;
zf=1;
if (zf==0){
c=' ';
*s++=c;
c='0';
while (data>=1000){
data -= 1000;
c++;
zf=1;
if(zf==0){
c=' ';
*s++=c;
c='0';
while(data>=100){
data -= 100;
c++;
zf=1;
if(zf==0){
c=' ';
*s++=c;
c='0';
while((uint8_t)data>=10){
data -= 10;
c++;
zf=1;
if(zf==0){
c=' ';
*s++=c;
*s++='0'+(uint8_t)data;
*s=0;
//終端付加
return head;
3)And finally from the same friend I have got the circuit diagram. What do you guys think about it. What should I do in order to create the ATmega32 version.(Focus on the receiver circuit, everything else is already modified and undercontrol)
Notice that I haven't built the circuit yet (planning to do this this weekend), so fell free to suggest anything you want. I am all ears.
Logged
Admin
Administrator
Supreme Robot
Helpful? 62
Offline
Re: 6-channel Futaba R/C receiver and ATmega32 communication
Reply #1 on:
January 31, 2008, 08:07:31 PM »
Its all described on this page:
http://www.societyofrobots.com/remote_control_robot.shtml
Basically you put the servo signal through a RC (resistor capacitor) circuit that converts PWM into an analog voltage (schematic is also on that page). Then you just feed that into an ADC and from there I trust you know what to do.
You might find that your analog signal has poor resolution, like from 8 to 12 on a scale of 0 to 255. If thats not good enough, put that analog signal through an
op-amp to amplify it
Logged
subscribe to SoR's YouTube account
Tsukubadaisei
Robot Overlord
Helpful? 0
Offline
Reply #2 on:
February 01, 2008, 02:24:38 AM »
Thanks for the answer. Your method is quite different for the one my friend told me but I will try both aproaches and post my results later.
In two or three weeks I will problably have a flying airship so expect a video.
Logged
Tsukubadaisei
Robot Overlord
Helpful? 0
Offline
Reply #3 on:
February 11, 2008, 02:52:35 AM »
hello again,
I tried ADMIN's solution. And it worked(but I had to use op-amps for 10x amplifying). Very simple and interesting idea ad I fell ashamed of myself because I already knew it but for another use... anyway, I appreciated the help very much.
Unfortunatelly there is a problem: the circuit was heavy. The total payload (3motors+sonar+controller+circuit+camera+battery) must weight less then 150g. Unfortunatelly there is no option but to try to read the PWM/PCM signal(the receiver manual says it is PCM but I read it using a oscilloscope). The good news is that I already got some readings, I think I just have to syncronize the controller timer with receiver timer in order to get correct readings.
If someone else has any suggestion or aything else that could help fell free to input.
And fell free to check this topic out:
http://www.societyofrobots.com/robotforum/index.php?topic=3197.0
it is a more general topic about our airship with pics ad eventually videos.
Last Edit: February 11, 2008, 02:59:58 AM by Tsukubadaisei
Logged
Admin
Administrator
Supreme Robot
Helpful? 62
Offline
Reply #4 on:
February 17, 2008, 09:58:10 AM »
consider getting your circuit made as a PCB using SMT parts
what is limiting the payload? I mean, can you use two blimps tied together?
Logged
Tsukubadaisei
Robot Overlord
Helpful? 0
Offline
Reply #5 on:
February 18, 2008, 11:08:58 PM »
Quote from: Admin on February 17, 2008, 09:58:10 AM
Next time I am going to consider this alternative. Every gram I reduce is a huge leap. For reference the RC circuit with the op-amp weigths only 6g but still...
Anyways I have got excellent news: I created my own solution. and managed to read the PWM only using software(similary to my friend but with much simpler code.)
Here is my solution: (notice that the only important part are the first 14 lines, the remaining code is the same but for each different port)
Code:
void radio(void){//ラジコンの出力パルスの幅を計る関数
int i;
//DDRA &= ~(1<<DDA0);
//PA0<->chan1
for(i=0;i<2;i++){
while((PINA&(1<<PINA0))==0){}
TCNT0=0;
TCCR0|=(1<<CS02);
while((PINA&(1<<PINA0))==1){}
TCCR0&=~(1<<CS02);
if(i==1){
chanVal[CHAN1]=TCNT0;
//printf("\r chan1 = %d\n",chanVal[CHAN1]);
wait_ms(2);
//DDRA &= ~(1<<DDA1);
//PA1<->chan2
for(i=0;i<2;i++){
while((PINA&(1<<PINA1))==0){}
TCNT0=0;
TCCR0|=(1<<CS02);
while((PINA&(1<<PINA1))!=0){}
TCCR0&=~(1<<CS02);
if(i==1){
chanVal[CHAN2]=TCNT0;
//printf("\r chan2 = %d\n",chanVal[CHAN2]);
wait_ms(2);
//DDRA &= ~(1<<DDA2);
//PA2<->chan3
for(i=0;i<2;i++){
while((PINA&(1<<PINA2))==0){}
TCNT0=0;
TCCR0|=(1<<CS02);
while((PINA&(1<<PINA2))!=0){}
TCCR0&=~(1<<CS02);
if(i==1){
chanVal[CHAN3]=TCNT0;
//printf("\r chan3 = %d\n",chanVal[CHAN3]);
wait_ms(2);
//DDRA &= ~(1<<DDA3);
//PA3<->chan4
for(i=0;i<2;i++){
while((PINA&(1<<PINA3))==0){}
TCNT0=0;
TCCR0|=(1<<CS02);
while((PINA&(1<<PINA3))!=0){}
TCCR0&=~(1<<CS02);
if(i==1){
chanVal[CHAN4]=TCNT0;
//printf("\r chan4 = %d\n",chanVal[CHAN4]);
wait_ms(2);
//DDRA &= ~(1<<DDA4);
//PA4<->chan5
for(i=0;i<2;i++){
while((PINA&(1<<PINA4))==0){}
TCNT0=0;
TCCR0|=(1<<CS02);
while((PINA&(1<<PINA4))!=0){}
TCCR0&=~(1<<CS02);
if(i==1){
chanVal[CHAN5]=TCNT0;
//printf("\r chan5 = %d\n",chanVal[CHAN5]);
wait_ms(2);
//DDRA &= ~(1<<DDA5);
//PA5<->chan6
for(i=0;i<2;i++){
while((PINA&(1<<PINA5))==0){}
TCNT0=0;
TCCR0|=(1<<CS02);
while((PINA&(1<<PINA5))!=0){}
TCCR0&=~(1<<CS02);
if(i==1){
chanVal[CHAN6]=TCNT0;
//printf("\r chan6 = %d\n",chanVal[CHAN6]);
wait_ms(2);
It is very straight:
1)the output from the receiver is connected to input(PORTA, PINA0~5 from ATMEGA32 but you can use any digital I/O you want)
2)when the output is up the timer(TIMER0) starts counting
3)when the output goes down the I save the value from the timer register in a variable(int radioVal[channelnumber])
4)as a filtering method I repeat step 2 and 3. The reason is because the controller is not syncronized with the receiver. So there is the possibility of starting counting from the middle of the PWM. if you repeat 2 and 3 just one more time the controller "syncronizes" with the reciever.
5)go to the next PIN
As for the schematics, there are none: just connect directly the receiver to the controller. You dont even have to worry about putting resistors in the middle because the receiver already has them.
The advantages of my method are:
->It is the simplest I know so far
->It requires only software
The disadvantage is:
->I think it is not as fast as ADMIN's solution. BUT, it is nearly impossible to notice the lag.
In other words: problem solved. It works great. If you want to use my code feel free to do so. It is the only way I can retribute the help. If I hadnt figured that code I would have used ADMIN's solution for sure. Thanks.
Logged
Pages:
1
Jump to:
Please select a destination:
General Misc
=> Misc
=> Robot Videos
Software
=> Software
Electronics
=> Electronics
Mechanics and Construction
=> Mechanics and Construction
Subject
Started by
Replies
Views
Last post
6-Channel Transmitter and Receiver
Electronics
garriwilson
2
888
December 17, 2007, 09:28:04 AM
by
garriwilson
Hitec or Futaba Servo Preference?
Electronics
Spoil9
2
877
April 26, 2008, 05:41:36 PM
by
Admin
have you used Futaba S3003 and S3102?
Admin
0
607
September 01, 2008, 11:00:45 AM
by
Admin
4 channel rf transmitter receiver.. help pls!
Electronics
BoB_the_BoT
3
830
March 07, 2009, 04:29:02 AM
by
BoB_the_BoT
Advertise on this Forum
Loading...
