Author Topic: pony prog seial prog circuit  (Read 4383 times)
Offline benjiTopic starter
« on: January 31, 2008, 09:41:33 AM »
hey guys, i just made the circuit found on the pony prog website for serially downloading the hex files into AVRs..
in the atmega adapter circuit i found out that there are pins called Vcc and others GND
well, are those the same power from the out of the lm293 regulator? or thats a seperate voltage source?
good ol' BeNNy
Re: pony prog seial prog circuit
« Reply #1 on: February 16, 2008, 06:03:34 PM »
datasheets define the pins ;D
but yes, you can connect both Vcc's if you want, and GND should ALWAYS be connected!
« Reply #2 on: February 17, 2008, 08:22:29 AM »
i think the LM293 regulator is put to power the avr using the computer serial port voltage,, neat,ha?
so i dont think you need any battery to program your avr
good ol' BeNNy
Offline izua
« Reply #3 on: February 17, 2008, 08:44:13 AM »
can you post a link to that circuit please?
i couldn't find it.
« Reply #4 on: February 17, 2008, 09:16:26 AM »
the LM293 is not a regulator ;D
« Reply #5 on: February 17, 2008, 12:18:32 PM »
no it is.  ;D (( LM2936z-5 ))
http://www.lancos.com/siprogsch.html
good ol' BeNNy
« Reply #6 on: February 17, 2008, 12:49:55 PM »
The LM293 is an entirely different chip than the LM2936! ;)
Offline Trumpkin
« Reply #7 on: February 17, 2008, 02:24:41 PM »
the LM293 is a comparator.....i think ::).
Robots are awesome!
« Reply #8 on: February 17, 2008, 05:02:38 PM »
mm i think its a dc motor driver
iwas writing LM2936z-5 as LM293 cuz i suggested its obvious i wont use a dc motor driver in an avr programmer ;)
good ol' BeNNy
