Author Topic: can i use stepper instead of servo?  (Read 3662 times)
Offline mohamedTopic starter
« on: February 02, 2008, 05:12:15 AM »
can i use stepper instead of servo coz i already have a stepper?
Offline benji
Re: can i use stepper instead of servo?
« Reply #1 on: February 02, 2008, 06:48:30 AM »
check your torque requirements, steppers with the same torque are much much more expensive
good ol' BeNNy
« Reply #2 on: February 02, 2008, 06:53:46 AM »
but arent servos usially cheaper than steppers? or can you get them for cheap?
« Reply #3 on: February 02, 2008, 07:06:35 AM »
i have this problem that i cant ind servo in my country and i didnt also find this ESC motor thing
i only have a normal dc motor with two wires so anyone can tell me how to connect it to the 50$ robot i'll be thankfull to him
« Reply #4 on: February 02, 2008, 07:08:10 AM »
what country are you in?
Offline Rebelgium
« Reply #5 on: February 02, 2008, 07:45:18 AM »
So what do you want to do now? use a stepper motor (4 or more wires) , or use a DC motor (two wires)?
anyway, to use a DC motor you'll need a motor driver, to use a stepper motor you'll need a stepper controller.
Do some research.
using a modified servo is much easyer, but if you really cant find it, then use a DC motor or a stepper
orgcrime.net
Offline ed1380
« Reply #6 on: February 02, 2008, 09:41:35 AM »
a stepper motor is harder to use than a regular dc motor.
check admins tutorial on h-bridges. I'm sure you can get 8 transistors or mosfets. and then make it yourself
Offline benji
« Reply #7 on: February 02, 2008, 12:03:42 PM »
if you need the capabilities of a servo its really hard to make it out of a dc motor yourself,its a total project cuz you have to do a decent driver.
using a stepper with big torque would cost yo a lot,,so try to buy the servos from a different country and have em shipped to you
good ol' BeNNy
« Reply #8 on: February 02, 2008, 12:18:55 PM »
i heard that the atmega32 has a built in motor driver so i think this will solve the problem for me as i can have a dc motor and put it on the atmega32 so if there is any problem with that plz let me know
but i dont know if i have to change the programming code or not
Offline ed1380
« Reply #9 on: February 02, 2008, 12:21:01 PM »
dc motor will suck too much current and fry the atmega
Offline paulstreats
« Reply #10 on: February 02, 2008, 12:37:47 PM »
I think you heard wrong.
What is probably meant is "the atmega 32 has built in pwm for use with a motor driver"
« Reply #11 on: February 02, 2008, 04:44:06 PM »
yes you are correct.
« Reply #12 on: February 02, 2008, 04:58:23 PM »
now i think thati dont have a solution except that i have to get the servo right?
Offline benji
« Reply #13 on: February 02, 2008, 05:09:54 PM »
right
good ol' BeNNy
Offline ed1380
« Reply #14 on: February 02, 2008, 06:33:21 PM »
or an ESC and dc gearmotor
« Reply #15 on: February 02, 2008, 06:58:28 PM »
well you can get servos for pretty cheap now. me? i use dc motors. lol ;)
Offline benji
« Reply #16 on: February 03, 2008, 05:19:04 AM »
did you make your own driver?(capable of imitating the hobby servos capabilities?)
good ol' BeNNy
Offline Rebelgium
« Reply #17 on: February 03, 2008, 07:03:42 AM »
no smash just much he uses dc motors for continuous rotation. He doesn't use them as servo's.
orgcrime.net
« Reply #18 on: February 03, 2008, 02:13:45 PM »
ok smash do u know how to use the dc motor with the 50$ robot i mean can u really coonect it to the microcontroller like the servo? ???
« Reply #19 on: February 03, 2008, 02:18:31 PM »
i havent built the $40 robot and if i did i probibly would use servos
Offline Rebelgium
« Reply #20 on: February 03, 2008, 02:55:21 PM »
mohamed read some tutorials and read the replies better. you can find this info everywhere on SoR.
To use DC motors you'll need a motor driver. You can't connect them directly to a microcontroller.
orgcrime.net
« Reply #21 on: February 03, 2008, 09:19:03 PM »
i do read the replies well but all i ment that if anyone did use the dc motor with the 50$ robot coz it will be i think and im not sure another programming code for the microcontroller that all im asking
Offline benji
« Reply #22 on: February 04, 2008, 11:12:48 AM »
you can never use a dc motor instead of servo if you want to use it as a servo unless you build the driver which is kind of impossible for a non-electronics engineer to do(its a big project itself)
in case you only want to turn the motor (left or right) you can hook up a dc motor driver ic with the micro and the dc motor
good ol' BeNNy
« Reply #23 on: February 04, 2008, 11:17:54 AM »
thank u benji for ur help as i already get the L293D motor driver ic but i dont know how to connect it to the micro so if u can help i'll be greatfull to u  ;D
Offline Rebelgium
« Last Edit: February 04, 2008, 11:46:55 AM by Rebelgium »
orgcrime.net
Offline benji
« Reply #25 on: February 04, 2008, 04:37:06 PM »
its all in the datasheet
good ol' BeNNy
Last post October 25, 2007, 04:35:34 PM
by Rebelgium
Last post December 01, 2008, 10:27:18 PM
Last post December 04, 2008, 05:41:44 AM
by Canabots
Last post July 22, 2011, 11:43:15 AM
by DangerousElectrician
