Author Topic: Wireless camera on a heli  (Read 1503 times)
Offline airman00Topic starter
« on: February 03, 2008, 05:55:42 PM »
I bought this camera
http://cgi.ebay.com/NEW-Wireless-Spy-Camera-Nanny-Cam-Security-CCTV-TV-W-CS_W0QQitemZ300195541765QQihZ020QQcategoryZ48632QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I usually ran it off a 9V battery like you are supposed to , and when I mounted the 9V battery and cam on my r/c heli, the heli rose to 10ft. I want  it to go higher than that mere 10ft.
So without the 9V battery it goes really really high.
Can I run the camera off the 7.2V battery pack thats already on the heli? Or can I use those tiny 9V batteries that are in cameras?
Thanks,
Eric
Re: Wireless camera on a heli
« Reply #1 on: February 04, 2008, 10:23:23 PM »
It says for the camera that if u use a 9V battery to power it , it'll last for an hour
so if I use  this 12V battery with three(or two) diodes to make a voltage drop I can power the camera for
http://www.allelectronics.com/cgi-bin/item/BAT-12/160/12V_BATTERY,_ALARMS___PHOTO_.html
or maybe I can boost the 7.2 V to 9V using a circuit like this
http://www.geofex.com/circuits/+9_to_33.htm
I need you guys to help!
EDIT: The 12V battery that is small is made up of small button cells inside!
« Last Edit: February 04, 2008, 10:24:15 PM by airman00 »
Offline Steve Joblin
« Reply #2 on: February 05, 2008, 08:51:33 AM »
it isn't just about providing the correct voltage... Amps (or in this case, Amp Hours) is the other aspect you need to look at... that is, how long can it provide the power that you need...
« Reply #3 on: February 17, 2008, 11:06:51 AM »
Couldn't hurt to try . . . I'm willing to bet it will work.
remember, the answers are in the datasheets ;D
http://www.societyofrobots.com/robot_faq.shtml#read_datasheet
Last post September 23, 2007, 04:58:42 PM
by sdk32285
Last post November 22, 2007, 10:59:02 AM
Last post February 21, 2008, 02:27:05 AM
by shadow57
Last post April 06, 2008, 12:55:18 PM
